Battery relocation made simple. Questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jul 12, 2015.
  1. Sep 29, 2021 at 1:56 PM
    #101
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Sub'd. Guess I found my next mod. probably next Spring time.
    Naveronski likes this.
  2. Apr 23, 2022 at 8:04 AM
    #102
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Are you still running this arrangement? I'm getting ready to relocate my starter battery to the passenger side and this is an attractive option, I'm waffling between doing this or running new cable down to the starter.
    Edit: To clarify, I'm asking about using distribution blocks specifically.
  3. Apr 23, 2022 at 2:08 PM
    #103
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yes I am.
  4. Apr 30, 2022 at 7:34 AM
    #104
    E.J.
    Josh
    NWA
    AM-JKLVCLjLIiM1-lsc6Yii7hqVmrzWJQjw08edq_5d296c141c3a2f548fe18665f1424594d4c4c9f7.jpg
    AM-JKLWmzlcnVOiDVHjyZcfsR4w-4kPR2qTcKC_I_5c8aea6bc3523a2af3cb024cc51dd86cdc8440e4.jpg
    Thanks to info in this thread I relocated my starting battery to the passenger side n my '17, thanks OP. I used the Painless Performance distribution blocks and 2 AWG welding cable to the battery, it's just under an 8' run so that seemed to be the sufficient size. It's working great but I'm not thrilled with the presentation so I'm thinking about picking up one of those HF Pelican case knockoffs to mount this stuff in.
    12TRDTacoma[OP] likes this.
  5. May 1, 2022 at 11:24 AM
    #105
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    @E.J. Does the on/off switch double as your battery isolator? I’m not intending to pick on you; just pointing it to others out as an option to the costlier isolator setups. It’s probably the most cost effective setup with the tradeoff that you have to open the hood to connect the second battery. I’ve seen the on/off switch placed inside the cab but that requires drilling holes in the firewall to route the wiring. What I don't see is the fuse in the wiring for the second battery - it should be placed as close as possible to the pos battery terminal. Maybe its out of sight under the cowl?
  6. May 1, 2022 at 11:28 AM
    #106
    E.J.
    Josh
    NWA
    The switch is just for my winch, I'm using a Redarc BCDC to manage the second battery. There's a fuse on the positive battery terminals on both ends.
  7. May 1, 2022 at 11:37 AM
    #107
    Chuy
    Lakeside, CA
    Silver Taco
    @E.J. Gotcha. I was hoping for the ‘poor man’ option to point it out as an option rarely seen. Guess I did that regardless.
    E.J. likes this.
  8. May 1, 2022 at 12:14 PM
    #108
    E.J.
    Josh
    NWA
    I definitely gave that option some serious consideration but 3rd gens don't charge AGMs exactly properly, they do sufficiently for a starting battery but not so great for topping off a house battery. My only regret with the BCDC was paying extra to have Off-grid Engineering pre wire it for the under hood dual battery arrangement, he did a beautiful job but I undid/re-did a bunch of it for the new house battery location behind the back seat.
  9. May 1, 2022 at 1:22 PM
    #109
    Chuy
    Lakeside, CA
    Silver Taco
  10. May 1, 2022 at 2:43 PM
    #110
    E.J.
    Josh
    NWA
    Those don't work on 3rd gens unfortunately, only way to change the charging voltage is with a tune.
  11. May 1, 2022 at 2:49 PM
    #111
    Chuy
    Lakeside, CA
    Silver Taco
    Bummer. Didn't catch you had a third gen.
  12. May 2, 2022 at 7:29 PM
    #112
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    There is a Ford factory part that does this same function at a cost of abou$12 vs $50 for the Australian one.
  13. May 2, 2022 at 8:25 PM
    #113
    Chuy
    Lakeside, CA
    Silver Taco
    @WOODY2 It was only $35 when I bought mine, and I knew about the cheaper part but I wanted the part designed for the function, and it has a money back guarantee.
    WOODY2 likes this.
  14. May 2, 2022 at 8:43 PM
    #114
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    What size fuse you running off the starting battery, I just mounted my relocation tray and am getting ready to install. I was under the impression that I should be using a 250/300 amp fuse just for starting
  15. May 3, 2022 at 5:31 AM
    #115
    E.J.
    Josh
    NWA
    I don't have a fuse between the starting battery and the starter. I didn't consider it because there wasn't one in the stock location, but it it sounds like good idea. Looks like the OP is using a 200 amp breaker for his relocation. The fuses I was referring to a few posts up are between my starter battery and DCDC charger, as well as the house battery and DCDC charger.
  16. May 3, 2022 at 6:55 AM
    #116
    E.J.
    Josh
    NWA
    Giving it some consideration I'm adding one of these to hold a 250 amp fuse for the starter and the 40 amp I'm running to the DCDC charger. If you look close at my previous pic you can see the single fuse version on the positive battery terminal. A resettable circuit breaker would be nice but I like this form factor.
  17. May 3, 2022 at 9:59 AM
    #117
    mysubiewasalemon
    Can you post a photo of how you have it setup now on the post
  18. May 3, 2022 at 10:09 AM
    #118
    E.J.
    Josh
    NWA
    AM-JKLXXTy8BFe33ZBtL7KMIrwfSn9QukjdWMxOr_c82d5b8597a43c5a3a2ee661565152f92aea66cd.jpg
  19. May 3, 2022 at 10:14 AM
    #119
    mysubiewasalemon
    So the one you want to go thru is one post and two different amperage? I guess I’m not understanding because I’m not going to be running two batteries .I’m just relocating my starting battery to the passenger firewall
  20. May 3, 2022 at 10:18 AM
    #120
    E.J.
    Josh
    NWA
    Yes. I'll set it up with a 40 amp fuse to the DCDC charger and a 250 amp fuse to protect the cable going to the starter.
