Battery relocation made simple. Questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jul 12, 2015.
  1. May 3, 2022 at 11:13 AM
    #121
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    No fuse is required, nor recommended, for the battery to starter cable. Amp draw varies but can easily go past 400 amps momentarily. You’ll be reducing your battery’s CCA rating to the fuse rating.
  2. May 3, 2022 at 11:45 AM
    #122
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Yeah, it had just occurred to me that my winch would pop a 250 amp fuse pretty easy as well. I'm going to leave it as is.
  3. May 3, 2022 at 11:58 AM
    #123
    E.J.
    Josh
    NWA
    Though explain this to me like I'm 5, what's the difference between the OP's 200 amp circuit breaker and a 200 amp fuse when it comes to degrading the battery's CCA?
  4. May 3, 2022 at 12:39 PM
    #124
    Chuy
    Lakeside, CA
    Silver Taco
    Note I am no auto electrician; this is how I see things based on research. The starter solenoid acts like a relay - when activated it allows the starter to draw power. In all other circuits, you want the correct rating fuse to protect the wire and its protected component from catching fire in the event it grounds. I’ve seen fuses labelled as a starter fuse in some vehicles, but it actually protects the starter solenoid, not the starter itself.
  5. Nov 16, 2022 at 9:46 PM
    #125
    erok81
    erok81 Well-Known Member
    Imposter
    This is a bit old but you guys really aren’t running any sort of fuse between the battery (in the bed) and the starter? I get marriage needed to start and the winch case, but running just a cable from the back to front with no safety protection makes me a little nervous.
  6. Nov 17, 2022 at 4:22 AM
    #126
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I can speak to this, made some poor choices and let the hot positive cable ground itself in the engine bay. But because I used a auto store braided cable that just burned through and acted as a fuse. A resettable water proof fuse would be better in line but the ones that can handle the draw of a winch are $$$.
    Naveronski and erok81[QUOTED] like this.
  7. Nov 17, 2022 at 9:27 AM
    #127
    erok81
    Imposter
    Maybe I’ll just use a fuse. With that much cable I really don’t like the idea of just leaving with no safety.
    Side note I was doing Simone google’ing and found another dude that was looking for a 400A breaker…because his sound system was pulling more then 350A. o_O
    Which then lead me down a path of how circuit breakers degrade after tripping and also vibration. Then I decided I might as well use a fuse.
  8. Nov 29, 2022 at 11:48 AM
    #128
    erok81
    Imposter
    I’m pretty sure I know the answer to this, but for the battery cable…any of you have luck with copper coated aluminum? Or just pure copper only.
  9. Nov 29, 2022 at 10:09 PM
    #129
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    You can always use it, but you likely need to gage up and make sure it s well clamped.
    erok81[QUOTED] likes this.
  10. Nov 29, 2022 at 10:26 PM
    #130
    erok81
    Imposter
    I think it’s just me trying to save money. I’m already pushing 500-600 bucks. The pure copper 1/0 is 140.00 for 25 feet. The CCA stuff is 40.00 for the same gauge and length.
  11. Nov 30, 2022 at 4:20 AM
    #131
    hoarder23
    Shay
    NJ
    Scratches
    I got my wires from www.batterycableSusa.com and their price is a bit cheaper that what you’ve found. But I’d also look at the wires specs they list and verify they meet your requirements. 16 feet was enough to go from behind drivers headlight to passenger frame rail forward of the axle on my DCSB with some slack.
  12. Nov 28, 2023 at 5:25 PM
    #132
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    bringing this thread back to life to see if anyone else wants to share their set ups. I will eventually be doing this probably in the summer of 2024. would also love to hear how much the final cost was to relocate to back of the truck. i'm thinking around a couple hundred dollars?
  13. Nov 28, 2023 at 6:19 PM
    #133
    hoarder23
    Shay
    NJ
    Scratches
    I moved my battery to the frame, passenger side just forward of the axle. All this was done in 2020/2021 so prices will likely be higher now. Check my build thread for pictures, and more details.
    Battery box - ruffstuff battery box - $75 (required welding that was done by a buddy while boxing the rear frame)
    Cables - 16ft 4/0 from dual power post to front of truck, 16in 4/0 from batt pos to dual power post, 20in 4/0 from batt neg to dual power post, universal braided ground strap from dual power post to frame - $200 (this is the final set but I used a smaller set for a bit that I decided wasn't up to the task and could cause a fire)
    Connectors - Blue Sea 2017 Dual Power Post, Blue Sea 2003 Power post, other various - $100ish
    The battery box was too close to the muffler so needed a new exhaust which was about $300
    I'm probably about $750 into this, there were places I spent more than I needed to but there were also places I saved a bunch. I run a winch up front so went with the 4/0, I did a lot of reading about power draw and current and didn't care to save $100 for thinner cable. The cheap grounding strap saved me once when I grounded the cable in the engine compartment, it burned through and opened the circuit, you don't want a strong ground, with a better ground it probably would have started a fire.
    Naveronski and spicy_fish_taco like this.
  14. Feb 23, 2024 at 1:08 PM
    #134
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Parts came in; hopefully I can relocate mine this weekend.
    spicy_fish_taco likes this.
