Battery Replacement...AGM or Lead
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WVTacoma08, Jul 22, 2020.
  1. Jun 2, 2022 at 8:55 PM
    #101
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Yeah I offroad and dd my Tacoma and have a abundance of accessories, winch ,amp , aftermarket hu , satellite radio, weboost cell phone booster , 3 sets of auxiliary lights , and use the stock inverter also another inverter. So definitely picking up a AGM battery tomorrow after work.
  2. Jun 2, 2022 at 8:56 PM
    #102
    shotgunbilly420
    Corrosion kills
  3. Jun 2, 2022 at 9:06 PM
    #103
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I take it your battery is corroding faster than usual? Battery corrosion is usually caused by gas and/or battery fluid escaping through the battery terminals. The cause can be a tired old battery, overcharging, or not venting the battery properly during charge cycles - charging warms up the battery fluid, causing it to expand. Those red and green felts help, as does coating the terminals with anti corrosion grease, and also regular cleaning. Or, get a new battery if battery fluid is leaking to the battery tray as it will eat through paint and metal.
  4. Jun 3, 2022 at 2:26 AM
    #104
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    When doing routine maintenance putting on a trickle charger a few times a year will do wonders for your battery life.
    shotgunbilly420 likes this.
  5. Jun 3, 2022 at 7:25 AM
    #105
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Replaced the battery in my wife's CX5 about 9 months ago. The platinum one from Advance Auto Parts. A few weeks ago I was changing the oil and noticed "blue fuzz" on my positive terminal. Also got onto the hold down bracket and started to go down the side of the battery. One of the caps was leaking. Not sure if it was from off gassing or an actually leaking from under the caps. Removed the cap. cleaned it up nice as well as the battery and reseated the cap on the battery. Disassembled the positive terminal and cleaned it up spotless in a baking soda slurry. Removed the hold down bracket and cleaned it up and repainted it. Cleaned everywhere else I could see the acid ran with the slurry then rinsed. Sprayed the terminal with terminal protectorate and will keep an eye on it. If it keeps doing it I'm returning it an putting an AGM in.
    shotgunbilly420 and Vmax540 like this.
  6. Jun 3, 2022 at 7:57 AM
    #106
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yep, excessive corrosion means the battery is on its way out.
  7. Jun 3, 2022 at 10:18 AM
    #107
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I guess you see this with ageing batteries (3+ years old) but if you're seeing it on newer batteries it's most likely leaking at the terminals. I've had two such batteries replaced under warranty with that issue. One, the OEM battery on my Gen 2 Tacoma @ about 1 year, and another on my wife's Camry @ 1.5~ years as I recall. Done by the dealership without quibble. If you're still under warranty and have such terminal corrosion issues, take it in.
  8. Jun 3, 2022 at 11:14 AM
    #108
    zoo truck
    None
    Geez, i hope not to see any corrosion in 3 years, or even 5. I'm use to that stuff after 8 years. All my oem toyota batteries have been pretty good lasting at least that long.
  9. Jun 3, 2022 at 11:24 AM
    #109
    shotgunbilly420
    I'm a gadget freak love my gadgets
  10. Jun 28, 2022 at 10:45 AM
    #110
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    When the Optima battery started in 1972. Off roaders discover this wonderful, powerful battery. It could be mounted anywhere, upside down if they wanted to. The abuse the off road vehicles went though, many batteries could not handle the tossing and bouncing. Very few seal batteries in those days. (AGM).
    When you google the history of Optima battery. You will not find “Why Optima batteries “SUCK” at a period in time.. It had started to earn a bad reputation. A past and forgotten time.
    It has change hands a few times. Today with new owners , it is a well design and well made battery today.
  11. Jun 28, 2022 at 1:39 PM
    #111
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    Did you do anything about charging voltage, or did you just roll with the 13.x the OEM alternator and ECU settings put's out? That's my only hesitation on getting an AGM battery.
    Jerry311SD likes this.
  12. Jun 29, 2022 at 2:39 AM
    #112
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    The Toyota Trus Start is made by Interstate, delivered on the Interstate truck and carries an 84 month warranty. I run them in our newer 4Runner, Highlander and my Tacoma. The Highlander's with 200k miles on it is on its 3rd Toyota battery and this one I just took out has been in since 2014, I know amazing right! I just replaced it before we drove it on vacation last week.
    TacoJoe480 likes this.
  13. Jun 29, 2022 at 10:44 AM
    #113
    Lava-road
    2019 trd-off road
    Thank you about the Interstate 84 month battery. That is a 7 year battery.
    Many ,many years ago Consumer Reports listed the Interstate as a Top brand battery to own.
    I run only Interstate battery. Costco sells Interstate batteries, and I am so happy Costco carries them. There return policy is so awesome! Costco Interstate is only a 3 year warranty.
    02Duck likes this.
  14. Jun 29, 2022 at 11:20 AM
    #114
    coma toy
    coma toy Off Road Taco
    I just get the cheapest Battery I can at Costco or Wal-Mart. They usually have one of the better warranties.
    AxisCab likes this.
  15. Jun 29, 2022 at 3:44 PM
    #115
    Lava-road
    2019 trd-off road
    Costco return policy is the best. I had a battery drain, 1 year old, Costco took it back and give two years of credit.
    I still got two more battery return credits worth ($15 each). Hard for me to find dead batteries. Still on my Costco membership, unbelievable they keep records this long. Years!
  16. Jun 29, 2022 at 3:52 PM
    #116
    zoo truck
    None
    Yeah like a 90 day warranty on there el-cheapo battery line. If you go that route, auto zone sells their econoline battery with a 1 year warranty. Imo, its better then the crapmart one.
  17. Jun 29, 2022 at 6:05 PM
    #117
    Lava-road
    2019 trd-off road
    A one year battery , if you got no money? Or selling the vehicle? A cheap save!
    I always carry a battery jumper (Gooloo & Nico) , in the truck and car.
  18. Jun 29, 2022 at 10:10 PM
    #118
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Where is a good place to get a AGM battery at?
    MGMDesertTaco likes this.
  19. Jun 29, 2022 at 10:16 PM
    #119
    MGMDesertTaco
    Walmart, 24F AGM 750cca; about $150-$160ish. Same battery Costco sells, but has a 4 year free replacement warranty instead of Costco's 3 year.
  20. Jun 29, 2022 at 11:36 PM
    #120
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Aww perfect thank you, and judging by your picture it fits in our trucks.
    MGMDesertTaco[QUOTED] likes this.
