Battery Replacement...AGM or Lead
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WVTacoma08, Jul 22, 2020.
  1. Jul 4, 2022 at 8:19 AM
    #121
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Will a 27f fit?
  2. Jul 4, 2022 at 8:35 AM
    #122
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Beware of adding too much weight. It can cause damage to the radiator support.... especially if offroading a lot.
  3. Jul 4, 2022 at 10:46 AM
    #123
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Jerry311SD[QUOTED] likes this.
  4. Jul 4, 2022 at 10:48 AM
    #124
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    AGM from batteries plus
    Jerry311SD likes this.
  5. Jul 4, 2022 at 12:56 PM
    #125
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Interesting topic. This is what was on Google. Note many brands differ in 24f & 27f categories
    Over all- the 24f produces more cranking amps and less reserve capacity then a 27f.
    27f has less cranking amps, but more reserve capacity. Varies brand to brand.
    Some 24f can weight more then a 27f battery, most 27f can be heavier, all brands will differ in weights.
    24f is usually 10” long vs 27f 12 inches long , varies brand to brand. 27f usually are more expensive.
    2016 and up the Tacoma tow packages only comes with 24f. 2015 w/ tow packages and below tow packages came with 27f.
    Buy a 2015 27f battery tray for the newer Tacomas if looking for a larger tray.
    2016 and up Tacoma Tow packages included a Trailer-sway control, engine cooler, transmission cooler, 4/7 pin connectors, 130 amp alternator, H/D battery (24f) & a Type 4 receiver hitch. Not sure rear size and gearing ?
  6. Jul 4, 2022 at 1:58 PM
    #126
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    All 3rd Gen V6 AT 3.91
    All 3rd Gen V6 MT 4.30
    tonered likes this.
  7. Jul 4, 2022 at 2:03 PM
    #127
    Lava-road
    2019 trd-off road
    Thank you. Lucky guys with the “ bigger rear end”
    shakerhood likes this.
  8. Jul 4, 2022 at 2:59 PM
    #128
    shakerhood
    Southern Ohio
    Off Roads, Pro's, and also MT SR and Sport have the larger 8.75" rear diff.
    tonered likes this.
  9. Jul 5, 2022 at 2:04 PM
    #129
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    You'll need a compatible base which is not super expensive or you ca make the OEM base fit. Bottom line, it will work but just not plug and play.
  10. Jul 5, 2022 at 2:15 PM
    #130
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Ill probably stay with a 24f
  11. Jul 5, 2022 at 3:18 PM
    #131
    Lava-road
    2019 trd-off road
    Best to watch the YouTube video - Battery box upgrade install , Rego Fabrication.
    When buying any aftermarket batteries.
    You will need to buy the positive side to be on the right hand side of the battery. Red terminal facing closest to center of engine and Red terminal facing back wall of the truck.
    Or the Red cables will not reach.
    Check you factory battery terminals first.
    As he mentions always remove the negative side terminal first.
  12. Jul 5, 2022 at 3:44 PM
    #132
    Skulky_Zebra
    Skulky_Zebra Well-Known Member
    2021 DCLB OR
    A lot of people talk about doing a dual battery set up with a lithium house battery. Why not just replace the starting battery with a group 24 lithium from battleborn instead? Seems like it would be a lot easier and a lot less components.
  13. Jul 6, 2022 at 10:20 AM
    #133
    Lava-road
    2019 trd-off road
    Sounds like your set-up worked out very well for you. Hurrah!
  14. Jul 6, 2022 at 10:33 AM
    #134
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    The point of dual is to have physical separation of the batteries to ensure the starter battery is never drawn down.
  15. Jul 6, 2022 at 12:50 PM
    #135
    Skulky_Zebra
    2021 DCLB OR
    I totally get that, but I think it would take a lot for me to draw down a 75AH battery to where it won't start the truck. Keep in mind you can draw the lithium battery to zero without really damaging it.
  16. Jul 6, 2022 at 1:55 PM
    #136
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Lithium batteries like that don't have the CCA of an AGM or led acid.
  17. Jul 6, 2022 at 2:39 PM
    #137
    Silverlogic
    Tyler
    You also can not draw a lithium battery to zero.
  18. Jul 6, 2022 at 2:50 PM
    #138
    Skulky_Zebra
    2021 DCLB OR
    So it would have trouble cranking the engine in the first place? Makes sense
