Battery replacement lead to dead truck....twice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ElGringo, Mar 21, 2023.
  1. Mar 21, 2023 at 10:58 AM
    ElGringo
    ElGringo [OP] Well-Known Member
    2019 Cement Grey
    2019 with factory battery. A parking attendant left the lights on a couple months ago and killed it deader than Kelsey's nuts. Had no issues after jump. Was preparing for a Sunday off road last week and noticed blue corrosion on positive terminal and struggled to start. not my DD... Replaced with 24F AGM. Drove home from the shop, a couple hours later won't start. Jumped and drove around for 30 min....same issue after a couple hours, dead. AutoZone says replace battery. No lights on dash. Took it back, they gave me a loaner battery (flooded) and are checking the AGM. Started fine, drove home, (10 miles half highway) dead again after a couple hours. Should I be looking at the charging system? Everything went to shit after the new AGM. I don't have any crazy loads, factory sound, nothing drawing increased load...35k miles....Ideas?
    toytaco112 likes this.
  2. Mar 21, 2023 at 11:03 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Have you tried to hook up a multi-meter and find out if you do have a parasitic draw on the trucks electrical system?
  3. Mar 21, 2023 at 11:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    Guessing you have something running hot after key off.
    What electrical accessories have been added? I'd start the hunt there.
    MGMDesertTaco, mquibble, Chew and 4 others like this.
  4. Mar 21, 2023 at 11:12 AM
    Old Man Tan 4x4
    Old Man Tan 4x4 Well-Known Member
    North East
    2017 TRDOR DCSB 4x4
    Dead alternator maybe? Off road debris can kill alternators pretty quick...
    PasoSteve and Stevie17 like this.
  5. Mar 21, 2023 at 11:17 AM
    ElGringo
    2019 Cement Grey
    Not yet....the battery has been flat dead. I'll drive it around and immediately hook up a meter to see what's going on. The only things I have are switched ditch lights and a bumper light bar. Everything else is what came from the factory. I guess I can start pulling fuses if I can get the thing charged up. Thanks
    auskip07[QUOTED] likes this.
  6. Mar 21, 2023 at 11:19 AM
    ElGringo
    2019 Cement Grey
    When the truck is running, I get 13.9v at the battery, I assumed this meant the alternator was working. I don't know much (obviously) am I wrong?
    rolled93slc likes this.
  7. Mar 21, 2023 at 11:21 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    I would start with unplugging the lights. Wait the time period that the battery goes dead and try again. If it starts, one or both sets of lights are the issue. Next try plugging one set back in and wait and repeat. If it starts, you know which set of lights to go after.
  8. Mar 21, 2023 at 11:30 AM
    Sigfourme
    Sigfourme Well-Known Member
    Frank
    Southeast CT
    2016 Tacoma Off- Road, Magnetic Grey
    AGM needs higher voltage to charge--14.4-14.8. Need to reprogram with Tune.
    Toolndie7, auskip07 and Mas Olas like this.
  9. Mar 21, 2023 at 11:33 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    very thisley
  10. Mar 21, 2023 at 11:42 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  11. Mar 21, 2023 at 2:12 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    His first battery was OEM, then AGM, and now a flooded again. It's happening regardless of battery type.
    auskip07 and shakerhood like this.
  12. Mar 21, 2023 at 2:15 PM
    gudujarlson
    Minnesota
    How does that change the charging requirements of a AGM battery?
    That said, I think that might be a subtle misunderstanding of the AGM battery requirements.
    https://www.centurybatteries.com.au...alk/issue-2-battery-talk-battery-charging.pdf
    “14.6 – 14.8V following deep cycle use, or 13.6V – 13.8V for standby use.”
    Deep cycle use is when you run the battery charge down a significant amount, e.g. running a fishing motor off it. Deep cycle use is not typical for an automobile unless perhaps you are running a fridge while camping.
  13. Mar 21, 2023 at 2:21 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    I bet the last thing you added is causing the problem. Remember
    Kiss
    Keep
    It
    Simple
    Stupid. Always something simple.
  14. Mar 21, 2023 at 2:54 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    That wasn't my point at all, rather I was pointing out that it has happened to 3 different batteries hours after shutting the truck off. Therefore by the Op not adjusting their output voltage for their one AGM battery is not a contributing factor in this instance.
  15. Mar 21, 2023 at 3:10 PM
    gudujarlson
    Minnesota
    I understood what you were saying, but I still don’t see how it applies to charging specs of the battery in question. Also, you can’t assume there is only a single root cause. Often there is more than one.
  16. Mar 21, 2023 at 3:19 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Ahhhhh, aftermarket electrical accessories……
    this is the 3rd or 4th thread in the past few days on something like this
  17. Mar 21, 2023 at 3:20 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I didn't mention any charging specs... And even if his voltage was 13.6V, which can be fine for an AGM battery depending on manufacturer, it wouldn't die a few hours after installation and shutting off the truck. I ran an AGM battery for two years on my 2017 Tacoma without any voltage adjustments from a tune.
  18. Mar 21, 2023 at 3:29 PM
    MGMDesertTaco
    Baking soda and water will dissolve any battery acid corrosion.
    I would start with disconnecting the light bar and ditch lights to see if that's what's draining the battery. Definitely sounds like a parasitic draw or possibly a failing alternator to me.
    Have you checked battery voltage with the engine running vs engine off? What about the alternator voltage? Have you checked for bad fuses/relays?
    https://www.youtube.com/watch?v=LGB6ZEjGm7Q
    ElGringo[OP] likes this.
  19. Mar 21, 2023 at 3:30 PM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    Gotta be. All the factory lights on the truck automatically turn off at the determined time set in the headunit.
    Stupid parking attendant!
    I bet the 4th battery will be fine.
    Stevie17 likes this.
  20. Mar 21, 2023 at 3:43 PM
    gudujarlson
    Minnesota
    You quoted a post that stated the charging requirements of an AGM battery and nothing else, which at the time seemed like relevant information to me. Anyway, this is a kinda pointless conversation at this point.
    kahanabob and Stevie17 like this.
