Battery Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Oct 2, 2013.
  1. Oct 2, 2013 at 4:26 PM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Thinking about relaceing the stock battery on my 07 in the near future. It looks like Johnson Controls no longer makes the Group 27F and Toyota now puts their name on the True Start brand. What are you guys paying for the 27F (tow package replacement) for this battery? My dealership quoted me a price of $165 installed.
  2. Oct 2, 2013 at 7:42 PM
    OffroadToy
    Update: After researching this more it appears the True Start brand is made by Johnson Controls and the battery (without installation) goes for around $96.
  3. Oct 19, 2013 at 6:33 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
  4. Oct 19, 2013 at 6:38 AM
    InSight Retrofits
    InSight Retrofits Closed
    Johnson controls makes almost every battery you see at every walmart, kmart, sears, advance auto, autozone, carquest and napa.
    I work at advance auto. All the prices are different by location but where I live its $116.99 installed. 710cca, 3 year free/60 month pro rate. Power frame plates inside.
    If you have an AAP you can order online, use the 15-20% coupon code, select pick up in store and have it installed.
  5. Oct 19, 2013 at 7:04 AM
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    Does it have to be that brand? There are plenty of aftermarket brands around that dealerships price that are much better. Oh and do you really need the dealership to install the battery, save the cash and do it.
  6. Oct 27, 2013 at 9:32 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Peter, what is a "Power Frame plate" and who currently manufacturers Advances private labeled batteries--Johnson Controls, Exide, East Penn, or Douglas?
