Battery Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hiker29, Jul 6, 2019.
  1. Jul 6, 2019 at 7:11 AM
    hiker29
    hiker29 [OP] Well-Known Member
    Southern California
    2007 -V6- 2WD Tacoma Double Cab-short bed TRD
    I replaced the original battery with "Toyota True Start" battery in 2013 in my 2007 Tacoma. It has seven-year warranty. I got 6 years and 30k miles out of it. I don't drive that much and I still do not have a slow start. It has a 12.3V reading when it is cold. I am planning a 2000-mile road trip. Thinking of replacing it. Any recommendations if I go with another brand? I also tow a small Casita trailer. Thanks!
    Athlaos likes this.
  2. Jul 6, 2019 at 7:12 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    walmart
    Lester Lugnut and hiker29[OP] like this.
  3. Jul 6, 2019 at 10:41 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Keep what you have.
    hiker29[QUOTED][OP] and BillsSR5 like this.
  4. Jul 6, 2019 at 10:46 AM
    Bishop84
    Bishop84 Well-Known Member
    I believe in changing batteries every 5-6 years in mild climate, but yours sounds ok.
    If you do buy one, consider interstate simply due to warranty and availability, you can have one warrantied on a sunday at a parts store without an appointment.
    Personally I would suggest a personal lithium ion booster instead as a precaution, they are great fail safes on trips.
    hiker29[OP] and Skyway like this.
  5. Jul 6, 2019 at 10:48 AM
    julioc1
    julioc1 Member
    Julio
    Denver, CO
    2015 Tacoma TRD OR
    Iv been running a optima yellow top for about a year and most of my buddies Run optimas red/yellow with no complaints 96D864C8-0CCF-4786-9857-D46E63DC5E1E.jpg
    HokieHT07 and hiker29[OP] like this.
  6. Jul 6, 2019 at 11:53 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Normal voltage reading at the posts should be 12.6 volts. You may have a cell starting to go bad, or it could be normal if some electrical components were on when you took the reading. Minimal cranking voltage is generally over 11.2 volts, and about 9.6 volts when cranking. But, voltage is only part of a battery's health. A battery load test is more accurate in testing the battery's health. You can use a mechanical tester, like a Schumacher BT100, or an electronic one like a Topdon AB101. All that being said, considering your long trip, towing, and age of current battery, I'd replace it for peace of mind.
    I would also add or replace the OEM ATF cooler with a larger one, but that's for another thread.
    hiker29[OP] likes this.
  7. Jul 6, 2019 at 1:52 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    OP - you did well with that True Start. I went thru 4 of them in another Toyota before I threw in the towel - apparently there were bad batches back when this was going on.
    Shop warranty and availability. They are all made by a small group of companies.
    For every person who says they've done well with Brand A, there is one who had a different experience. Batteries are the luck of the draw.
    cytocycle and hiker29[OP] like this.
  8. Jul 14, 2019 at 2:47 AM
    jtaco11
    jtaco11 Well-Known Member
    Costco went w 27 since it fills up the space better. 24 there alot of room around battery area
