Battery reprogramming
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nanau_beznez, Feb 3, 2025.
  1. Feb 3, 2025 at 9:26 AM
    Nanau_beznez
    Nanau_beznez [OP] Member
    Northern New Jersey
    2017 Tacoma SR5
    If I replace the battery on my 2017 SR5, are there any extra steps (reprogramming?) that need to be taken? Recently had to have tech replace battery on wife’s 2019 VW, instead of doing it myself, for this reason.
  2. Feb 3, 2025 at 9:30 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Never had any problems replacing the battery on my 2018.
    It did take a couple minutes for the AC to start working right.
    Nanau_beznez[OP] likes this.
  3. Feb 3, 2025 at 9:33 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    No you don't need to register the battery like you do on alot of Euro vehicles.
  4. Feb 3, 2025 at 9:35 AM
    Draxxas
    Draxxas Active Member
    2018 TRD 4x4
    Nope. I just did the battery replacement in my 2018..plug and play, unlike my wifes MB.
  5. Feb 3, 2025 at 3:52 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Just had my battery replaced. I think it lost its shifting points and needs to re-learn.
    t0p_d0g likes this.
  6. Feb 3, 2025 at 3:55 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    It may need to do throttle relearn but your TCM needs an actual reset learned command from Techstream. Disconnecting the battery would not cause this.
  7. Feb 3, 2025 at 3:57 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    You're good brother, drive on!
  8. Feb 3, 2025 at 4:16 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Probably don't need to do anything.
    Mine was replaced and nothing needed.
    Replaced battery on wife's Honda.
    Some things were not correct right away but after driving a bit and waiting a day or 2 all was fine.
  9. Feb 3, 2025 at 7:08 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    wow, I never heard of having to reprogram for a battery change! Reason #5,682 to stay away from German vehicles.
    IronratPR and ZColorado like this.
  10. Feb 3, 2025 at 7:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea some of the Euros have been like that for quite some time.
    Many of the newer Ford's your supposed to reset the Battery Monitoring System when you replace the battery but it often doesn't get done.
    Most newer vehicles generate a ton of low voltage, communication, and other "ghost" codes when the battery get's weak that ideally should be cleared with a scan tool but typically don't affect anything.
    Chew[QUOTED] likes this.
  11. Feb 4, 2025 at 9:24 AM
    nds0000
    nds0000 Well-Known Member
    If you replace with the same type and power battery, you should be ok, as other members wrote already. If you change type (liquid acid to AGM or other) or have significant power increase, you may have to have your ECU flashed.
