Battery shot?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Aug 16, 2020.
  1. Aug 16, 2020 at 2:16 PM
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Hey guys,
    so I have a 2018 with 49k miles on her. Out of the blue this morning my truck wouldn’t turn over. Loud rapid clicking and nothing. Got it jumped in no time with cables. The positive terminal had blue gunk on it. So I’m thinking the battery is shot. Is this normal for a 2018 with semi-low miles? Seems soon for this kind of crap.
    Also, would this still be under warranty? I bought it new 03/18.
  2. Aug 16, 2020 at 2:17 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Batteries are a crap shoot. Don't know about warranty, I'd think under bumper to bumper yes, but not after that.
    ejewels[OP] likes this.
  3. Aug 16, 2020 at 2:19 PM
    tcjacado
    tcjacado Well-Known Member
    Blue stuff is corrosion.
    Pull the terminals and clean the connectors and posts.
    06Tacooo, ejewels[OP] and shakerhood like this.
  4. Aug 16, 2020 at 2:20 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Good point, definitely should be cleaned either way.
    Also electrical mods will affect battery life if they have lots of amp draw and/or you're running the battery down while not running.
  5. Aug 16, 2020 at 2:21 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    2018...2 years/22K...replaced under warranty
    ejewels[OP] and Hank Heel like this.
  6. Aug 16, 2020 at 2:23 PM
    vintage_carrot
    vintage_carrot Well-Known Member
    2020 SR5 DBL Long Bed
    I had a post a couple months back in like March of 2020. I just bought my 2020 in January and the battery was bunk. I kept trying turn it over but nothing would give! I went back a Toyota Certified dealer for a replacement battery. Was free with my warranty. 2 weeks later, another bad battery. Bad luck I suppose, but they replaced it again! So far it's been 3-4 months on this (3rd I guess) battery. Could just be shoddy work and dwindling Quality Assurance.
  7. Aug 16, 2020 at 2:28 PM
    JaysTRDsport
    JaysTRDsport Well-Known Member
    AJ
    2020 Tacoma Trd sport 4x4 6spd manual
    Toyo off road tires
    Depends on the battery & use over time I had a 12 year old battery Finally die finally die on one of my show cars bought it from kragen auto parts I keep the Terminals disconnected Terminals disconnected When it sits & clean them when installing it to drive as for warranty unless you bought an Extended warranty most expire at 36k miles 3 years so at 49k I would say no not coverd.i use interstate battery’s But on my Tacoma is new with only 5k Miles so won’t be changing mine for awhile
    ejewels[QUOTED][OP] likes this.
  8. Aug 16, 2020 at 2:29 PM
    BGXtobe
    BGXtobe Well-Known Member
    Central Valley, CA
    2016 MGM TRD Sport 4x4
    The factory batteries don’t last very long, from what I’ve seen on here a lot of guys have gotten about 3 years out of em at the most, some a bit more.
    My 16 died at the 3 year mark about 42k miles and thats considering I wasn’t a heavy user(lights on all the time, audio/bass real loud, etc.)
    I don’t believe the warranty will cover it since it’s considered “routine maintenance” or something like that, you can still try and see what they can do for you?
    I’m not sure wether the warranty is based off the mileage of the vehicle or the years but 2 years/ 49k miles is pretty soon in my opinion.
  9. Aug 16, 2020 at 2:31 PM
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    49k no warranty
    I'd clean them up and see what happens.
    shakerhood, ejewels[OP] and tcjacado like this.
  10. Aug 16, 2020 at 2:37 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    It’s hit and miss with factory batteries, some report no issues with their batteries many miles later, mine died at 22k miles, truck was completely stock.
    ejewels[OP] and BGXtobe like this.
  11. Aug 16, 2020 at 2:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    Pull the battery. Take it to a parts house and have it load tested. If it tests good, reinstall, clean terminals, see what happens.
    Call dealer and ask re:warranty. Batteries warranty on time, not miles, when you buy them on your own. Don't know how Toyota treats them. Hopefully time like the industry standard.
    If you need a battery, the correct Interstate at Costco will probably be your best buy, but they don't install.
    What would be interesting is to know is who makes Toyota labeled batteries. If it's a hodge podge or single vendor. @Jeff Lange , any input?
  12. Aug 16, 2020 at 2:56 PM
    ejewels
    CT
    Thanks guys! I took a wire brush to the blue corrosion but still had an issue. I will call about warranty. If not, if I take it to auto zone or similar, will they check the voltage and determine if I need a new one? And if so... do they install?
    ive been running the A/C a lot so not sure if that does it...
  13. Aug 16, 2020 at 2:58 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    OP, being in CT I think you should expect longer from the battery. It's not like we had a horrible winter recently.
    My 2010 puked the original battery January 2019, almost 10 years. Clean the corrosion on your posts, use a dab of dielectric grease, and charge er up
    Tacotsubo, ejewels[OP] and over60 like this.
  14. Aug 16, 2020 at 2:59 PM
    ABA180
    East Bridgewater MA
    Take the posts off..clean inside the clamps too and then do what I posted just now.
    Autozone or Advance will be able to load test it and make the call..and yes if you buy a new one they should install free but IDK about presently with Covid19.
    Come visit us on the NE BS thread man, welcome aboard!
  15. Aug 16, 2020 at 3:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    Load test, not 'check voltage'. You can simulate one at home if you have a DVM, but theirs will be more thorough
    They do. But unless you have no alternative sources, they will also be a fair amount higher than places like Costco or Sam's. Even AAA may have a competitive price if you are a member, and they'll come to you.
    Battery removal/installation is a simple task unless you have a physical condition that makes lifting it out and in difficult.
    Not at all.
    The primary function of the battery is to start the vehicle. The alternator produces enough current at the correct voltage to support 100% of systems operations + 'extra' to recharge the battery.
  16. Aug 16, 2020 at 3:09 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    i wouldnt doubt it. my sequoia at the beginning of the year had the battery just up and die. left us stranded, good thing we was at the mall, and interstate is right down the street. picked up a new optima, then when i took the sequoia in for its service i told them about the battery and they reimbursed me for the new batt. so it all worked out. they told me that basically its just a luck of the draw. when these new vehicles is made they have these new batteries thats just been sitting on the side that they pop in. so it couldve been slow drained.
    on the flipside? if this was my truck, put that badboy in gear, roll it down and bam; kickstart. moral of the story? cant beat manual trans. :laughing:
  17. Aug 16, 2020 at 3:33 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    While I haven't seen the corrosion, it often continues under the insulation where you can't see it. This greatly increases the resistance. When in doubt replace both cables.
  18. Aug 16, 2020 at 6:42 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The battery falls under the 3/36 warranty, with 49K you are long past it.
  19. Aug 16, 2020 at 7:54 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    take tools to change the battery to Costco, make sure they have the battery in stock, pull out the old one and wheel it in and get the new one and exchange and install.
    one stop shop...that's what i did anyway.
  20. Aug 16, 2020 at 8:03 PM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Same situation as you.
    My factory battery went out at 43k. I replaced it with one from Costco thsts 700 something cycle with a 3yr warranty. I have a volt meter in cigarette lighter it read 9 volts when it should be 12-13 or better.
