battery sparked on tray
Discussion in 'Technical Chat' started by tacoman68, May 4, 2012.
  1. May 4, 2012 at 10:48 AM
    tacoman68
    tacoman68 [OP] Well-Known Member
    Rio rancho nm
    4X4 08 Tacoma with ENGAGE long travel
    O8 Tacoma with Engage long travel front and rear 2.5/12 with resi and 2.0 bump stops up front with engine cage have bed cage with king 2.5/16 with resi and 61.5 deavers and 13in. Shackles with 2.0 bumps as for engine have douge thorny headers cold air intake and short shifter installed in tranny have racing seats with 4 point harness full alpine sound system
    so i have a problem my battery cable hit my battery tray and sparked now my truc wont stay on ive gone over the whole thing by eye does any body have any ideas of what could have happen it an 08 taco
  2. May 4, 2012 at 10:50 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    DID YOU CHECK ALL FUSES
  3. May 4, 2012 at 10:50 AM
    Aw9d
    Aw9d That one guy
    Az
    x2
    Does the truck start up then die? or is it just not starting at all?
  4. May 4, 2012 at 10:51 AM
    DrewH
    DrewH Well-Known Member
    /\/\ This
  5. May 4, 2012 at 4:33 PM
    tacoman68
    Rio rancho nm
    it starts then it dies out after about ten minutes and where is the main fuse i checked fuse box everything is good computer is good im stumped...
  6. May 4, 2012 at 6:16 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Mike, can you answer a few questions about this ? When you say it starts, does it start normally,or does it barely turn over ? Have you put a meter on the battery while it is running to see if the battery is getting charged ? When you say it dies after 10 minutes, Does it shut off quickly or sputter then cuts off ? Can you restart the engine after it dies ?
    If you can answer some of theses questions, I am sure more people will be able to give some more help with this. Good Luck.
  7. May 5, 2012 at 9:33 AM
    tacoman68
    Rio rancho nm
    i have not puta metter up to the battery yet but if i disconnect the postive side it stays running off the alt. it does not turn over right away it takes a couple of cranks and when its turnning off it kinda sputters but everything dies all lights and i can not restart the engine once it dies..
  8. May 5, 2012 at 9:57 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    There are two boxes, did you check 'em both?
  9. May 5, 2012 at 10:02 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Have the battery tested you may have fried something in there. Which side did you disconnect? Always unhook the Negative first that way it stops the circuit.
  10. May 5, 2012 at 10:27 AM
    DrewH
    I'd say your battery took a shit.
  11. May 5, 2012 at 10:29 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
  12. May 7, 2012 at 3:33 PM
    Warhorseforever
    Will
    Sand Lapper
    Lol This made me laugh........ YOU KNOW WHO......
