Battery terminal bolt stuck...HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma4, Jan 7, 2013.
  1. Jan 7, 2013 at 4:09 PM
    tacoma4
    tacoma4 [OP] Well-Known Member
    I'm trying to wire fog lights and attach the positive wire to the battery terminal. Problem is it is tight as SHIT!!!! The clamp just spins around and digs into the post on the battery. I disconnected it and tried vice grips but the metal starts to bend and I can't get a good grip on this damn bolt. How can I get this thing off? Pic is just a random one I got off the internet but thats the bolt I am talking about.
  2. Jan 7, 2013 at 4:13 PM
    Backinblack03
    Backinblack03 Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    Can you gently put a little torch heat on it and give it a quick twist with a strike of a hammer on your wrench/ratchet? The shock will usually break it loose and the heat will soften any threadlocker that may be there from the factory...
  3. Jan 7, 2013 at 4:20 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Why won't a socket fit on it? ViceGrips are not really meant to remove bolts, they do more damage than good.
  4. Jan 7, 2013 at 4:20 PM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
  5. Jan 7, 2013 at 4:23 PM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    ELECTRIC IMPACT :D
    Real quick and easy
  6. Jan 7, 2013 at 4:53 PM
    tacoma4
    I tried a socket, it just spins around on the battery post. I will soak it in some PB blaster I guess...kind of afraid to go at it with the torch with all the wires and rubber around there.
  7. Jan 7, 2013 at 5:01 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    I'd try the impact too. All you need it a bit or resistance on the other end and it should pop loose.
  8. Jan 7, 2013 at 5:04 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    The bolt head on the other side is spinning. Hold it with something then try loosing the nut.
  9. Jan 7, 2013 at 5:07 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    remove the battery terminal from battery....
  10. Jan 7, 2013 at 5:12 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Try putting a pipe over the end of your ratchet to increase leverage.
  11. Jan 7, 2013 at 5:13 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    are all you people nuts?
    going to have the guy ruin his terminal......
    also op
    just put your + wire to battery bolt instead and be done.....
    don't use a torch or a lever
  12. Jan 7, 2013 at 5:19 PM
    samiam
    Sam
    Stinky Vegas
    It worked for me. That is a crazy tight bolt.
  13. Jan 8, 2013 at 7:11 AM
    tacoma4
    Wish i saw this last night. I finally got the bolt off. I put 10mm wrench on the small bolt and wedged it against the battery to keep it from turning on the terminal. Then i could really torque on the bolt and it broke loose. Them found out the round end was too small for the bolt so i ended up putting it on the small side bolt anyway. Damn it! Thanks for the help. Now i just gotta get the dash done.
