Battery Terminal Corrosion
Discussion in 'Technical Chat' started by Chris(NJ), Jun 22, 2010.
  1. Jun 22, 2010 at 11:58 AM
    Chris(NJ)
    Chris(NJ) [OP] Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    The terminals on my battery all pretty corroded. I'll obviously need to clean them up real well, but was wondering, is there a better battery wire terminal clamp that I should look in to? Or am I being ridiculous and just clean these up, grease 'em and get on w/ life.
  2. Jun 22, 2010 at 12:00 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'd got with the brush 'em, grease 'em' and get on with it plan...
  3. Jun 22, 2010 at 3:02 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    yea, I kinda figured that, lol.
  4. Jun 22, 2010 at 3:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    after you clean them/grease them.....get some terminal spray and liberaly spray them down with it.
  5. Jun 22, 2010 at 3:15 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Use baking soda and water to clean them, and wire brush.. the best you can do.
  6. Jun 22, 2010 at 3:17 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    You can buy a set of felt washers for the posts that have a lube soaked into them, they always worked in my past vehicles.
  7. Jun 22, 2010 at 3:31 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Make sure before you use anti-corrosionspray, that you put on the + - terminal leads. Don't want to start a fire. :bananadead:
  8. Jun 22, 2010 at 3:34 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
  9. Jun 22, 2010 at 4:01 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    :thumbsup:
    interesting. Never seen them before.
    You mean, just connect them before spraying them, right?
  10. Jun 22, 2010 at 4:36 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    +1 on baking soda and water.
    When dry, battery terminal protectant spray.
  11. Jun 22, 2010 at 7:44 PM
    tacosuprem
    tacosuprem Well-Known Member
    Florida
    4x4
    pour some coca cola on it.
  12. Jun 22, 2010 at 8:04 PM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    x2 they cost about $2.00 at most auto parts stores
  13. Jun 22, 2010 at 8:24 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    I've used the felt washers and they didn't seem to help, I could have just had crappy ones, I've also used the spray on terminal protector stuff, it works pretty well, as well as anything I have used. Spray liberally on the terminals, the cable clamps, and any exposed cable wire, do that after cleaning and re-installing the cables as said above. One of those wire brush things made specifically for cleaning the terminals and the inside of the cable clamps works well, they are pretty cheap at autozone et. al. Baking soda/water mix plus an old toothbrush to neutralize any leftover acid, (best way is disconnect the battery, take out the battery, and scrub the entire battery, especially the top, avoid allowing the water to make a connection between the terminals, wouldn't hurt to use the baking soda solution to also clean the battery tray and hold down bolts, after scrubbing with the b-soda wipe good with wet paper towel to remove all crud, then dry good with paper towel) and if the cable wires show any corrosion where they attach to the terminal clamps, they should be replaced. Not hard, takes a little time, but by doing all that I've had pretty good luck with avoiding corrosion.
  14. Jun 22, 2010 at 8:27 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Clean them with baking soda & water & an old toothbrush. Make sure you do this on the street or it will stain your driveway.
    The cover them with petroleum jelly(vasoline).
    Thats all there is to it.
    MadDaddy likes this.
  15. Jun 22, 2010 at 8:57 PM
    dually
    dually Low and slow
    Coke is an acid. What would that do? You need a base to combat the acidity of battery 'acid'.. c'mon here, basic science.
  16. Jun 23, 2010 at 5:08 AM
    tacosuprem
    Florida
    4x4
    Try it. It works.The Acid eats the corrosion. Look it up buddy. Works better than baking soda............
  17. Jun 23, 2010 at 7:25 PM
    dually
    dually Low and slow
    Why do I need to try it? My batteries dont corrode.
    Oh and i looked it up.. results are inconclusive. Id rather not have my battery all sticky.
  18. Jun 23, 2010 at 8:25 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Well, heres what I'm working with. As I began to remove the terminal connector, it just about snapped off! Had to run to the parts store to pick up a new one. Gonna finish tackling this tomorrow.
    On a side note, I have no idea how it got like this. When I changed the oil in early April, it was no where near this bad! In fact, I really dont even remember it having any corrosion on there at all at that time.
  19. Jun 24, 2010 at 4:56 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Ya that looks bad. You will probably need to replace the cable and terminal (& possibly the battery).
    Looks like the cap is loose on the left side. The gasses from the acid cause the corrosion.
    I have had good luck with those little red and green felt circles. They sell them for $1 at all auto parts stores. I guess they are treated with some oil or something. I have tried the sprays and pastes but those felt pads work best for me.
  20. Jun 24, 2010 at 5:50 AM
    tacosuprem
    Florida
    4x4
    If your battery doesn't corrode then you have no need to try it then...
    When i do use coke i do wash them. Common sense isn't it? Maybe you should try to search again. I found plenty of websites... Just make sure you don't have any spelling errors.
