Battery tests good, but says to replace.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 5nahalf, Feb 10, 2021.
  1. Feb 10, 2021 at 5:14 PM
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    My truck has had to be jump started every day for the past week. I finally got into the dealership to have them test it. They came back and said the battery was good.
    Here is their print out. This is after driving for 15 minutes, and sitting on their charger for 40 minutes.
    They wont replace it under warranty because it says "good battery" at the top, but "replace" at the bottom.
    tacotoe and BigWhiteTRD like this.
  2. Feb 10, 2021 at 5:15 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Something is fishy...makes no sense.
    xxTacocaTxx, GarlicFarts and tacotoe like this.
  3. Feb 10, 2021 at 5:16 PM
    5nahalf
    Erik
    Minnesota
    Also to note, when I put my tester on there, it comes back with a open cell (code f01)
    tacotoe and Bleep100 like this.
  4. Feb 10, 2021 at 5:23 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    12.26 volts is DEAD! You may also have something draining it overnight. Like an Amp not shutting off.
  5. Feb 10, 2021 at 5:24 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I'd say your battery is poop. I just started my 2018 yesterday after sitting since last Friday and not problems. It was -5F when I did.
    The weekend is supposed to be brutal
    Tacowin1013 and Bleep100 like this.
  6. Feb 10, 2021 at 5:27 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    368 CCA on a 580 CCA battery and it's "good"... morons1
  7. Feb 10, 2021 at 5:28 PM
    5nahalf
    Erik
    Minnesota
    I pulled all my fuses and hit the breaker on my amps a little bit ago. Going to check in the morning if it starts... if not its back to the dealer she goes.
    Last year she started great in the cold. This year it was starting a little slow before the cold snap, then I have had to jump it each day since it got below 10 degrees.
    tacotoe likes this.
  8. Feb 10, 2021 at 5:28 PM
    5nahalf
    Erik
    Minnesota
    What I find funny is even the bottom of the tester says "replace"
    xxTacocaTxx and tacotoe like this.
  9. Feb 10, 2021 at 5:30 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I would go to another dealer or have another tech run the test, the battery is absolutely bad per the numbers, the cold snap killed it and it should be replaced.
    GarlicFarts, Tacosrus and tacotoe like this.
  10. Feb 10, 2021 at 5:32 PM
    MGMDesertTaco
    GarlicFarts and cwdog like this.
  11. Feb 10, 2021 at 5:37 PM
    Gswain
    Gswain Eastern sierra living
    Also check the terminals to make sure they are clean. Sounds like battery is shot but doesnt hurt to check.
    Taco_Coma likes this.
  12. Feb 10, 2021 at 5:40 PM
    5nahalf
    Erik
    Minnesota
    The advisor said anything between 12 and 12.4 is ok after I told him nominal votage should be at 12.4... I just looked at him and said no, 12 is 100% dead, 12.1 is 75% dead, 12.2 50% dead.
    The only other dealer is even worse than this one. At least at this dealer they dont screw up everything.
    Canufixit likes this.
  13. Feb 10, 2021 at 5:43 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    If they say it's not the battery again tell okay fix whatever it is then .
  14. Feb 10, 2021 at 5:45 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    The measured voltage is not really important to battery health, only to the state of charge.
    The CCA tested 368 which is 63% state of health (based on 582CCA rating).
    My tester fails the battery at 80%.
    Battery needs replaced.
  15. Feb 10, 2021 at 5:45 PM
    Tacoma Mike
    Southern Maine
    that’s a junk battery.
    We have this problem with the new super duper tester we HAVE TO USE.
    There are ways
    tacotoe likes this.
  16. Feb 10, 2021 at 5:47 PM
    5nahalf
    Erik
    Minnesota
    Yeah, I hate the warranty tester. Between taking so long, and being pretty shitty at testing.
  17. Feb 10, 2021 at 5:48 PM
    MGMDesertTaco
    I had to pull teeth and raise a stink to get my battery replaced under warranty at the dealer. It was less than a year old and I was constantly having to clean the terminals and battery caps due to leakage. I had cleaned it off before my scheduled appt. and they claimed their was no sign of leakage.:rolleyes:
    Maybe ask for the service manager and explain that you have to jump it constantly. The service advisor is misinformed.
  18. Feb 10, 2021 at 5:49 PM
    Tacoma Mike
    Southern Maine
    We put the car outside.:D Do it there.
    Customers get pissed because we “aren’t working on their car for 2 hours”...
  19. Feb 10, 2021 at 5:51 PM
    5nahalf
    Erik
    Minnesota
    If it doesnt start again tomorrow im going to go in again when there are service managers there.
    lol, when I worked for VW we just hooked up a known bad battery.
  20. Feb 10, 2021 at 5:51 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
