Battery tests good, but says to replace.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 5nahalf, Feb 10, 2021.
  1. Feb 11, 2021 at 6:23 AM
    #41
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    https://testmeterpro.com/parasitic-draw-test-with-a-multimeter/
    Had to go through this on an '08 silverado.
    Basic procedure: Disconnect the negative, connect a multimeter in series in current mode, read the amp draw.
    If you see a reading of around 50mA and above on a standard car, it generally means something is drawing power and you likely have parasitic draw. Just note that if you have a big, modern, luxury car its added computerized systems will likely increase the natural current draw. In this instance, the threshold might be 100mA. (This is from link above).
    It's not like a parasitic draw will be 52mA, where the norm is 50mA, and you might just be confusing a normal draw with a parasitic draw. That silverado was up around 250mA or 450mA (it was a while ago) and very much so a flag.
    IF there is parasitic draw, but it just sounds like you got the shit end of the unlucky stick that is the junk stock batteries they use.
  2. Feb 11, 2021 at 6:28 AM
    #42
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    It sounds like these batteries are junk. If I were in MN I would not want another one even if covered under warranty. It's not worth the time (for me at least) dicking with the dealership. I would just buy a quality battery and move on.
  3. Feb 11, 2021 at 6:50 AM
    #43
    DW72
    DW72 New Member
    2021 Tacoma SR5
    All dealerships have the "battery tester"! If the truck has no starting issues you most likely don't need a battery.
  4. Feb 11, 2021 at 7:27 AM
    #44
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    So little update from this. Last night I disconnected all my electronics to let the truck sit overnight. Its -7 out and I went to start the truck this morning. Fired right up. So I plugged everything except my light bar. Looking at the light bars wiring, the relays are pretty ugly looking with corrosion. Im going to let the truck sit for awhile with everything but the light bar plugged in and see if it starts in the morning.
    Im still going to get a new battery, because the test they did would indicate a crappy battery to begin with.
  5. Feb 11, 2021 at 7:50 AM
    #45
    cosmic65charlie
    cosmic65charlie Consumer of good times.
    Colorado
    2019 TRD OR AC
    Offroad stuff, Audio stuff, Cooler full of beer
    Was going to say the same thing. Warranty a Northstar AGM? Sure. Waste my time with the stock battery? Nope. As it is I'll be replacing my stock battery way before it ever gives up.
  6. Feb 11, 2021 at 7:52 AM
    #46
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Honestly if it was me and they refused to change it the first time, i'd just go out and pick up an interstate battery and call it a day. IMO its not worth the headache and stress of dealing with those scumbags. Just my $0.02
  7. Feb 11, 2021 at 7:54 AM
    #47
    5nahalf
    Erik
    Minnesota
    Thats the plan right now. Looks like I have a draw in my light bar right now thats draining the battery power overnight. The battery in the truck is still trash, so I am grabbing a new agm from costco this weekend (have to order it)
    MGMDesertTaco likes this.
  8. Feb 11, 2021 at 7:58 AM
    #48
    Tacowin1013
    My 2017 midwest life battery is probably due for a change, plan is to swap it later this year before the next winter. $100 bucks and peace of mind is worth it. I hate wasting 3-4 hours at a dealership only for them to say then can't find the issue and won't replace. Nothing more aggravating when you know it needs replacement.
    shakerhood and blitzkrieg3002 like this.
  9. Feb 11, 2021 at 8:30 AM
    #49
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    The crappy part about having Toyota replace the battery under warranty is that your best case scenario is they give you a new crappy battery.
    After several failures under warranty for my wife's Rav4 and the stories here, I pulled my stock battery before it died and replaced it with an AGM replacement.
    It's just not worth the hassle of getting stuck somewhere and then having to wait and argue to a dealer about the replacement.
  10. Feb 11, 2021 at 8:34 AM
    #50
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    Wouldn't waste another second with the dealer. Had similar issue with a Toyota battery, still under warranty. Took it out of my Sequoia and drove to dealer only to have them tell me they needed the whole vehicle and refused to even test the battery. Went straight to Autozone and simply bought a new battery.
  11. Feb 11, 2021 at 8:44 AM
    #51
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Sounds like you are finding a potential drain on the battery. Fix that, then replace the battery.
    Strongly suggest to get a Batt with as many CCA as possible. Look for CCA above 750A, the more the better for sub-zero starts.
  12. Feb 11, 2021 at 8:47 AM
    #52
    5nahalf
    Erik
    Minnesota
    In my old BMW, when the battery went out we put in a a group 49 in it, 1000 cca and it fit in the battery tray in the trunk. That battery made the starter spin so fast in sub zero weather.
    Im planning to get a agm interstate battery.
    Skydvrr likes this.
  13. Feb 11, 2021 at 8:54 AM
    #53
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you grab a battery tray from a 2nd Gen with tow package then you can go with a 27F battery.
    5nahalf[QUOTED][OP] likes this.
  14. Feb 12, 2021 at 1:13 PM
    #54
    5nahalf
    Erik
    Minnesota
    Well guess my theory of a drain on the system was not right.... battery dead again today. So its off to costco once I get enough charge in the battery to get a new agm battery.
    shakerhood likes this.
  15. Feb 12, 2021 at 1:28 PM
    #55
    MGMDesertTaco
    Bummer, get it swapped and be done with it. Let us know how those agm's from Costco are. :thumbsup:
  16. Feb 12, 2021 at 1:35 PM
    #56
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    and the price please, I know their standard Interstates are around 90 where I live, curious about the AGM ones.
  17. Feb 12, 2021 at 1:39 PM
    #57
    5nahalf
    Erik
    Minnesota
    159.99 for the agm
    89.99 for the regular one
    Their web page says they dont have any though, but Im still going to try to get one... if they dont have it ill just get the regular one till the agm comes back in stock... then put the regular one into my convertible.
  18. Feb 12, 2021 at 2:36 PM
    #58
    5nahalf
    Erik
    Minnesota
    Ok so decided to try the dealer again since costco didn't have any batteries in stock for the AGM.
    I raised a little more hell this time and they are putting in a new battery. They will try to fail the old one later.
  19. Feb 12, 2021 at 2:37 PM
    #59
    Tacoma Mike
    Southern Maine
    Good
  20. Feb 12, 2021 at 2:47 PM
    #60
    jimmerheck
    Vancouver, WA
    Thank you!
