Battery tests good, but says to replace.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 5nahalf, Feb 10, 2021.
  1. Feb 12, 2021 at 3:24 PM
    #61
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Tell them to do a load test on the battery .if dealer won’t run the test then take it to batteries plus they will do it .have them print you out the results . Take that back to the dealer to prove the battery is bad .
  2. Feb 12, 2021 at 4:02 PM
    #62
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    They did do a load test, but they are bound by the warranty. While they know the battery is bad and I know the battery is bad, they need the machine to say its bad and provide a test code. Pretty much all dealers are like that. The battery is so boarder line on the tester that being below zero outside just kills it overnight.
