Battery upgrade
Discussion in 'Technical Chat' started by alopez910, Feb 18, 2015.
  1. Apr 18, 2017 at 9:49 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Northstar AGM 27F
    Sandman614 likes this.
  2. Jun 27, 2017 at 3:01 AM
    SilverwolfTacoma
    SilverwolfTacoma New Member
    '08 Tacoma DCSB SR5 4X4
    New to Tacoma world here.. Does anyone know if the stock alternator will maintain the XS Power D3100?
  3. Jun 27, 2017 at 3:39 AM
    alopez910
    alopez910 [OP] Well-Known Member
    Tony
    South Texas
    2009 DCSB TRD Sport Prerunner
    It should, but look into a Northstar AGM 27F. You will not be disappointed.
  4. Jun 27, 2017 at 5:40 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    It depends on the total electrical load on the alternator, driving habits, and temperature. An easy way to tell it to measure the battery voltage with a digital meter before you first start you engine. If it is not reading a full charge ~12.8 VDC or greater, and the alternator is not able to keep the battery fully charged over time. The battery will start accumulating lead sulfate and you will start losing performance (CCA) and capacity until it eventually prematurely fails. This is a very common problem when aftermarket large audio systems are added to OEM alternators.
  5. Jun 28, 2017 at 5:18 AM
    SilverwolfTacoma
    The thing is I haven't bought a new battery just in case the OEM alternator won't maintain the charge to a larger battery. I do have the tow package so I'm assuming I'm pushing 130A off of it. All questions being that I'm installing a 2800W system for two 10" subs that push 800 RMS each. They are DVC and apparently the wiring option for 4 ohms is the same as 2 ohms, but my monoblock has separate ratings for each. The 4 ohms being the full 2800w and the 2 ohms only being 1500w. Should I just do the Big 3 with 1/0 AWG? The same as my amp wiring, with either the Northstar or XS Power and my alternator should hold it's charge?
  6. Jun 28, 2017 at 6:27 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Simply stated, after an engine is started, the battery becomes a temporary storage device to make up of the difference between the total electrical vehicle load and the output of the charging system. The output of the charging system is based on the alternator's voltage regulation and RPM. Let's assume that you have a 120 amp rated alternator output at 3500 RPM and the total electrical load is 100 amps. Let also assume that at 1500 RPM the alternator is only producing 80 amps, the battery will make up the difference of 20 amps until it is discharged. If you factor in stop and go city driving the alternator's output will vary greatly, so more power is required from the battery. That is why "driving habits" are a major factor in premature battery failures due to the gradual build up of lead sulfate. If the engine is not running, the battery obviously supplies all of the electrical power to satisfy the vehicle's electrical load until it is discharged.
    When there is a shortfall of power produced by the charging system and the battery is not recharged, there are couple solutions. First solution is to top the battery off with smart battery charger so that it can achieve a full charge to prevent sulfation and the second is to upgrade the charging system to a higher output charging system. I believe that you will find that the second solution will ultimately be a better choose when you start replacing alternators or batteries. In the interim, the first solution will prolong the life of the battery. If you decide to upgrade your alternator, driving habits can make the proper sizing tricky. For more information, please see Section 5 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  7. Jun 28, 2017 at 6:32 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
  8. Jun 29, 2017 at 3:09 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    After much research/consideration, I found nothing to convince me that any battery at any price lasts any longer than any other. I'm sticking with the OEM 27F. I've had very good luck with them over many years. It has plenty of CCA's and reserve capacity, 7 year warranty, fits perfect (my gen 2 came with a 24F w/option for a 27F). $139 dealer installed.
  9. Jun 29, 2017 at 1:58 PM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    What is your worst case current requirements and driving habits?
  10. Jun 29, 2017 at 3:33 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Why would the capacity of the battery affect the ability of the alternator to recharge it? It might take a little longer if you allow the battery to discharge extensively, but as long as there's charging going on, it'll charge whatever battery is there. Dual battery setups don't seem to need bigger alternators, and they're maintaining at least twice the Ah capacity of the factory battery.
    A 130A alternator will make 1820Watts at 14V, and if you're not rolling around with the volume near or at max on those subs, you shouldn't be drawing enough to be constantly discharging the system, and if you are running that much power into the sound in a truck cab while you're in it you'll have bigger problems than your battery in pretty short order (in my experience, even a 1000W system driving a single 8" bazooka tube plus 4 6.5" mains has far more capability than you'll likely want to sit that close to, if you run a 2800W system over 20% while inside the cab expect your teeth to rattle and forget ever seeing anything in your mirrors).
    It probably wouldn't be a bad idea to put a real-time volt meter reading at the battery just to keep an eye on things though considering how inexpensive and simple it is to do. With the engine running, as long as the VM is reading 13-14, you're only drawing off the alternator, whenever it dips to 12 (or less), you're drawing down the battery
    06Tacooo likes this.
  11. Jun 30, 2017 at 3:28 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
