Battery Voltage Diagnosis - Helpful Reference Chart
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TX Tacoma, Oct 1, 2012.
  1. Oct 1, 2012 at 10:20 AM
    TX Tacoma
    TX Tacoma [OP] Fightin Texas Aggie
    Arlington, TX
    The attached chart has helped me diagnosis battery issues in the past, so I'm sharing it.
    Hats off to my buddy Doug for putting this together.
  2. Oct 1, 2012 at 11:02 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i like!!
    gonna shrink it and print it onto a sticky Avery label, the stick it to my toolbox.
  3. Oct 1, 2012 at 11:12 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    load test
    1/2 cca for 15 secs shouldn't drop below 9.6v. Make sure no surface charge.
  4. Oct 1, 2012 at 1:21 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Redneck alternator test:
    Turn on heater fan to high, high beams, hazard lights, wipers to high, and measure voltage at 1500-2000 rpm. It shouldn't be much lower than when the loads are switched off, 14 - 14.5V
    Redneck battery load test:
    Measure battery voltage while cranking ( pull EFI relay). If it drops below 10 V, when your battery was 80% charged or more (table above), you have a weak battery, or possibly a high starter amperage draw. The first is MUCH more common.
    Proper test equipment far exceeds these for accuracy, but for a backyard guy trying to get by, they work most of the time. That said, if you don't get clear results, get a proper test done.
  5. Oct 1, 2012 at 6:03 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Thanks for the info. Printed it off. I have a pod mounted gauge, now I have something to measure the volt meter reading to.
