Battery voltage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acgreen01, Jan 11, 2024.
  1. Jan 17, 2024 at 7:28 PM
    #61
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Any major difference in 2021+ trucks?
  2. Jan 17, 2024 at 7:28 PM
    #62
    acgreen01
    acgreen01 [OP] Well-Known Member
    Andrew
    2012 silver 4wd regular cab
    I still prefer toyota but the frontier was runner up for me
  3. Jan 17, 2024 at 7:30 PM
    #63
    TnShooter
    Deogee
    STOCK
    Only time I seen that happen was in a Ford Escape.
    Neighbors transmission went to slipping, towed the truck home. Transmission full of coolant.
    Bishop84[QUOTED] likes this.
  4. Jan 17, 2024 at 7:37 PM
    #64
    545
    545 Well-Known Member
    2015 Access Cab
    They stuck the new engine in, but now I’m thinking it was 2020? They sold the old truck with new engine and transmission for a year or two. Odd but it’s Nissan, soooooo
    Then they had the whole new truck in 22
    Not that it’s bad, seems to be pretty good actually, but the 4.0 with 5 speed auto are really reliable. Stick shift ain’t bad either, but goes through clutches more than it should
    TnShooter[QUOTED] likes this.
  5. Jan 17, 2024 at 7:56 PM
    #65
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    So why don’t you buy it at auction then? Sell your single cab privately! My cousin got 25k for his 2012 single cab 4x4 stick last year!
    Also, unless you get it done under warranty, no freaking way I would pay to have the timing cover re-sealed the “proper” way! Unless it is a gushing leak (it’s probably more of a seep, right?), you just remove the belt and PS pump, clean the area real good, and seal from the outside with grey PTex. Wait a day before running the engine. I’ve done this on my 2007 four years ago. But it’s slowly starting to seep again. Oh well, I’ll do it again maybe soon. About 250k on the clock now. It’ll get a V8 swap before any major engine work lol.
  6. Jan 17, 2024 at 7:58 PM
    #66
    acgreen01
    Andrew
    It was leaking so bad everything was covered all the way to the rear diff. The truck ended up being neglected.
  7. Jan 17, 2024 at 8:03 PM
    #67
    TireFire
    Olympic Peninsula
    The fan does blow it all over. It’s the engine’s way to try and provide the rust proofing Toyota failed so miserably at.
  8. Jan 17, 2024 at 8:36 PM
    #68
    acgreen01
    Andrew
    That and I don't need a project truck with a baby about to be born.
    1schoir and TnShooter like this.
