Battery warranty
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BBBsti LTD, Jan 23, 2012.
  1. Jan 23, 2012 at 9:48 AM
    BBBsti LTD
    BBBsti LTD [OP] Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    I have a 2010 Tacoma with 22,000 miles it will be 2 years in March. My battery is leaking fumes, that causing one of the terminals to get the white corrosion. You can see the trace of teh fumes coming from the negative side cover to the negative terminal.
    I want to know if anyone know Toyota battery warranty policy. The battery is holding the charge fine and it's not causing any problems at all, other than the white corrosion that keeps coming efter cleaning the terminal.
    I don't want to waste my time and take it to the dealer if a replacement won't be approved since the battery is charging and working "fine". I rather buy a new baterry.
  2. Jan 23, 2012 at 11:20 AM
    Harleyfx69
    Harleyfx69 Well-Known Member
    try putting the fuzzy covers over the battery, they absorb that acid fumes..
    Also all batteys except sealed ones do this leaking a bit aroud the posts
  3. Jan 25, 2012 at 11:24 AM
    rkupiec
    rkupiec New Member
    Ron
    Wadsworth
    PreRunner SR5 Badged
    Pioneer head unit,fog light switch,bed lights,tailgate mod
    Just got mine replaced. Toyota tested it and found it "bad". Warranty is 3 yrs or 36000 miles. They have to determine it is bad through testing to get the warranty.
  4. Jan 25, 2012 at 11:31 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    put some lemon juice in one cell. do not use baking soda it will bubble up all over the place and cause rust issues you dont have yet
  5. Jan 25, 2012 at 11:33 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    The hell?!
    Just call the dealer if there's a warranty claim.
  6. Jan 25, 2012 at 3:08 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    call the dealer lol
  7. Jan 25, 2012 at 6:34 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Mine did the same thing. I dealt with it for almost 2 years and then it died in the cold. New DieHard is now keeping me going. In your case, give the dealer a try...Free is always nice.
  8. Jan 26, 2012 at 6:20 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    For battery warranty, yes, 3/36 covers it. I had mine replaced 2.5 years into it, but mine was dead. I would suspect that they are not going to replace it though unless the case is cracked or a battery test comes out bad. A bit of build-up is normal, might want to post a pic to see it anyone thinks it's abnormal.
  9. Jan 26, 2012 at 9:50 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I had mine replaced after 2 years under warranty. It was out-gasing fumes and battery acid. The new one is starting to do the same. It may have something to do with 115 degree weather in the summer.
    I stay on top of it with the felt terminal protectors and anti-acid spray.
  10. Jan 26, 2012 at 3:45 PM
    jw1983
    Alberta
    Yeah! I ain't waiting for my battery to crap the bed. A company here in town has Optima red tops on for 175 CDN from a Christmas special. I am going to be heading there tomorrow and getting one. Screw the OEM battery lol.
  11. Feb 11, 2012 at 4:09 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    So if I have an extended platinum warranty is my old dying battery covered?
  12. Feb 11, 2012 at 4:31 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Good question. I don't know the answer but I'd certainly try to get it taken care of at the dealer.
  13. Feb 11, 2012 at 4:38 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    When I worked at the dealership, we used the acid removing, color changing in acid, spray. We scrub off the corrosion with a wire brush, and rinse, dry with compressed air. Then we coat it with a red protectant spray. I don't recall the name, but it was marked as a battery terminal sealer/protectant.
    The vehicles that came in with the red spray never had any corrosion on the terminals. I was sold on it, and use it.
  14. Feb 11, 2012 at 5:41 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I work at Lexus and we had the same problem with our cars. There was a defect in the battery causing excessive corrosion. There was a TSB on this. Replace battery, check/replace terminal. Some cars were so bad that the cable needed to be replaced also.
  15. Feb 13, 2012 at 7:51 AM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Called 3 dealers and then the Platinum Warranty line. Not covered past 3/36.
