Battery Wiring
Discussion in 'Technical Chat' started by NorthWoods, Aug 18, 2013.
  1. Aug 18, 2013 at 5:28 PM
    NorthWoods
    NorthWoods [OP] Well-Known Member
    Seacoast NH
    '15 TRD OR SW
    So, currently I have my Hellas and light bar connected to my battery for power. Pretty soon it will be a CB as well. My question is, can the battery handle all this stuff (and potentially more) wired to it? Would a second battery be a good investment? Or can I just keep stacking on to the terminal?
  2. Aug 18, 2013 at 5:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Use an aux fuse block like the Blue Sea. Feed it with a 4ga length of wire and install a 60a marine breaker at the battery.
    Stacking wires on the terminal looks horrible and makes it harder to troubleshoot when you have a problem.
  3. Aug 18, 2013 at 5:50 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I assume the light bar is LED so low power consumption and not used while driving at night. Hella's are halogen. Might be used but not that much and the CB as well. I don't see why your battery (single) can't handle all that. Maybe you can invest in a AGM if you wanted too but dual battery you would want when you plan to add more accessories like winch and etc.
  4. Aug 24, 2013 at 7:00 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    A high output alternator might be a better investment unless you can not keep your battery charged.
