Battle scars from working on your truck?
Discussion in 'General Automotive' started by FlyingWolfe, Jul 16, 2020.
  1. Nov 1, 2020 at 4:32 AM
    #101
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I don’t even remember what happened here several years ago. I think I was working on my rear suspension.
    But it was the same damn fingertip I cut off recently.
    So I actually got rid of a battle scar.
    Skada, 3JOH22A, EldenRivas and 3 others like this.
  2. Nov 1, 2020 at 6:29 AM
    #102
    My Name is Rahl
    I guess. It's a free country.
    We have some with a Kevlar lining that helps with that. The cut wheel may still go through, but the injury is not as bad.
  3. Nov 12, 2020 at 7:37 PM
    #103
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    now your hand matches the end of your sleeve. :welder:
  4. Nov 12, 2020 at 10:27 PM
    #104
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Removing the stupid side steps off a new F-150 today, whoever put them on must have given it 10 Ugga-Duggas because I was yarding with one hand with all my might and the socket slipped off. Hand flew into a sharp sheet metal edge under the body and laid my damned thumb wide open. About an inch long and completely through the skin. It’s wrapped up now, don’t want to sit for 6 hours in the emergency ward with a bunch of coughing COVID patients.
    Bigdaddy4760 and wilcam47 like this.
  5. Nov 13, 2020 at 8:47 PM
    #105
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    That sweatshirt has caught fire at least once, has some sort of bleach stains on it, and is by far my favorite. :laughing:
    Luckily I bought 2 of them probably 11 years ago now, the other one is just getting broken in.
    Bigdaddy4760 likes this.
  6. Nov 13, 2020 at 9:07 PM
    #106
    eon_blue
    Azusa, CA
    I'm ordering a full body chainmail suit for when I use my angle grinder thanks to this
  7. Nov 26, 2020 at 2:48 PM
    #107
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    No picture, but worst close call was almost sucking my hand into my fairlead installing my winch. Wake up call for sure...not all toys are toys.
  8. Nov 27, 2020 at 5:40 AM
    #108
    FlyingWolfe
    FlyingWolfe [OP] Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    A family friend got complacent with a log splitter last year after the repetition for several days and accidentally activated it while his hand was against the wedge. Broke every bone in his hand, hes in double digits for surgeries but he can finally kind of use it again. Has scars all over his fingers like Dr.Strange
    Bigdaddy4760 and Ensemble88 like this.
  9. Nov 27, 2020 at 6:50 AM
    #109
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Honestly just working on the vehicles it's mostly just cuts and scrapes luckily. Now as an industrial maintenance technician I've gotten a couple good ones. First one that stands out I was running the stick welder nice and hot laying on my stomach on the ground. Soon as I get done I roll over and instantly feel something "poking" my butt cheek. Somehow I rolled over on a hot slag that burned through my work pants and boxers. Still have a scar on my butt from that (and no you can't have pictures). Was one was pulling a new belt through a conveyor which I had to stand on another one to do it. All was good until I went to jump off and my leg caught the side pan. Didn't fall too bad, but slammed my kneecap into the MCP panel that left a nice bruise for a month. Alot of places it's quicker to walk under a conveyor, many of which you have to duck. Got me one day as I crouched back up too quick and hit the back of my head on the metal support. Knocked me on the ground and left a nice goose-egg on my head. Funniest one was a co-worker put a new master cylinder on an electric tugger. They didn't bench bleed it and couldn't get it to bleed the conventional way. I decided to take the brake line off the cylinder and do it that way. All was good until I took my finger off the fitting too early and doused my entire face and front of my shirt with fresh DOT3. I was dubbed the "brake fluid bukakke king" the rest of the night...
  10. Nov 27, 2020 at 2:47 PM
    #110
    FlyingWolfe
    Crystal
    Maine
    My old DC1 on the cutter figured out why you weld with your mouth shut. We still dont know how tf it happened but he got slag under his helmet and in his mouth. We were 200 miles offshore and he had to suck it up the rest of the deployment with basically a hole in his tongue. o_O
  11. Dec 15, 2020 at 6:50 AM
    #111
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Avoid open-end wrenches on high-torque applications if you can. Use the box end or a socket, which grip the fastener on all 6 sides to reduce rounding. If there's no access, use a flare nut wrench.
    I have Chineseium "JobMate" wrenches that cost less than $15 for the whole set. Been using them for 17 years maintaining five vehicles with no issues. Just need to know the limitations of the tools by design.
    I had a welder accidentally drag a bright orange TIG electrode through my finger once. (I was holding down the workpiece.) It went through with no resistance like a lightsaber and cauterized the wound as it went. Luckily didn't sever any tendons. That was also 17 years ago (before camera phones). Still have a scar to this day.
  12. Feb 20, 2021 at 3:28 PM
    #112
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Not many from working on it, but a fair number while using it. From the heat shield of the cat when installing sliders. Knicked it a few times and thought "i should go put on gloves" right as I sent it home. Took forever to heal since it was right on the crease. Every bend split it open again.
  13. Feb 28, 2021 at 10:14 PM
    #113
    spence13e
    spence13e Well-Known Member
    NCK
    2021 Barcelona Red Tacoma OR MT
    NA
    I avoid hurting myself wrenching on things. I've found certain varieties of pain from certain things perfectly acceptable. I don't mind whacking myself in the knee driving nails while shoeing horses. Or cutting myself with a hoof knife or rasp. But damned if a wrench or socket slips loosening something and I hit something harder yet, I get downright unpleasant in a hurry. That's not acceptable pain.
  14. Feb 28, 2021 at 10:21 PM
    #114
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Pinched my pinky between the 2 piece driveshaft as I was taking it out. Nail was all purple and wasn’t letting me sleep from the pain caused by the pressure of all the blood under the nail. So I just stuck a knife under the nail and pulled it out....what a relief
    Tacoma Mike, Skada, Sharpish and 2 others like this.
  15. Mar 1, 2021 at 3:22 AM
    #115
    FlyingWolfe
    Crystal
    Maine
    :puke:
  16. Mar 1, 2021 at 7:21 AM
    #116
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :eek:
  17. Mar 1, 2021 at 7:23 AM
    #117
    wilcam47
    Will
    Bourbon state
    MalinoisDad likes this.
  18. Mar 1, 2021 at 7:31 AM
    #118
    texas angler
    texas angler Well-Known Member
    Texas Hill Country
    20 OR
    Yeh ouch to some of this I’ve read. No injuries to me by any of my Tacomas but I’ve injured a few along the way.
    I did chip off part of one of my front teeth working on my dirt bike just last summer. Never, ever force a nut off loaded under pressure by a spring. Never. Extremely lucky I didn’t lose an eye.
    Y’all be careful out there.
    wilcam47 likes this.
  19. Mar 1, 2021 at 7:32 AM
    #119
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    My scars are purely emotional.
    :rofl:
  20. Mar 2, 2021 at 5:17 PM
    #120
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Most noticeable one. Was trying to break loose the upstream O2 sensor on the driver side. It finally broke loose and I went flying back....I made contact with the useless bracket in the driver side wheel well. Took a nice piece of skin/fat off. This was WITH gloves on
    pahaf, FlyingWolfe[OP] and wilcam47 like this.
