Bazooka or Infinity Basslink?
Discussion in 'Audio & Video' started by trdracing5, Mar 6, 2011.
  1. Mar 6, 2011 at 3:54 PM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    Does anyone have any experience with the Bazooka line of Bass tubes?
    I am looking for something to add a little bit of punch in my wife’s Sequoia. I would prefer an “all-in-one” powered subwoofer versus having a separate amp and sub. I also want something that will not take up much room.
    We have an Infinity Basslink in our 4Runner and it sounds GREAT. I was thinking about getting one for the Sequoia but wanted to find out if the Bazookas were possibly better. Any opinions?
    The Basslink has its own wired volume control which cost $20 extra for the Bazooka so the Basslink has a slight advantage there, other than that the prices are about the same.
    I am leaning towards the Basslink but wanted to hear from some others that might have some input on the bazooka.
    Infinity Basslink
    Details:
    • 10" woofer and 10" passive radiator
    • Class D 200-watt amplifier
    • wired volume control with 16-foot cable
    • frequency response 20-120 Hz
    • low-pass crossover variable from 50-120 Hz at 12 dB per octave
    • speaker and line-level inputs
    • phase switch
    • bass boost adjusts from -6 dB to +3 dB at 40 Hz
    • 20-amp fuse
    • auto turn-on with speaker-level inputs
    • remote turn-on lead (12V) required for use with RCA inputs
    • 19' speaker-level input wires with plug-in harness included
    • 14-1/2"W x 13-3/8"H x 9-7/8"D (vertical mount); 14-1/2"W x 9-1/2"H x 15-3/16"D (horizontal mount)
    • warranty: 1 year
    Bazooka BTA 10100
    Details:
    • 10" woofer with foam surround
    • power output 100 watts
    • 85 Hz low-pass filter (18 dB/octave)
    • line- and speaker-level inputs
    • 2-ohm impedance
    • frequency response 39-85 Hz
    • subsonic filter (12 dB/octave at 35 Hz) for improved amp efficiency
    • sensitivity 107 dB
    • 20-7/8"L x 10-3/8"W x 12-1/4"H
    • warranty: 1 year
