BD 3rd gen fog light gap
Discussion in 'Baja Designs' started by Anterrabae, Sep 23, 2021.
  1. Sep 23, 2021 at 6:08 PM
    Anterrabae
    Anterrabae [OP] Well-Known Member
    AK
    20 TRDOR Cement
    https://imgur.com/a/1WAjDkM
    That’s the smallest 360 degree gap I can get between the light and truck bezels and that’s with the mounts loose and me pushing on the back of the light…and that’s jamming way more of that rubber isolator than I should on the inner feet.
    I tried putting both mounts in loose to see if I can pivot the assembly around but it gets no better. The only way I’m able to get it to look like it’s been advertised is to mock the light up without the inner mount and rotate the light counter clockwise but then the mount hole on the light for the inner mount doesn’t line up.
    I’ve used up all the isolator trying different ideas and have come up empty. Does DB only sell the lights that install correctly to youtubers or is there something that I’m missing?
