BDS 6” Drop bracket lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Local Deluxe, Jan 25, 2020.
  1. Jan 25, 2020 at 1:58 PM
    Local Deluxe
    Local Deluxe [OP] Member
    Question, the BDS lift kit says it comes with 2.5” fox coilovers for the front , I’m just curious where does the remaining 3.5” lift comes from to get that total 6”.
    For the rear it comes with fox 2.0 shocks & a 4” block so I’m assuming both of those combined makes it 6” in the rear? I have no idea how lifts work. Sorry for the noob question.
  2. Jan 25, 2020 at 2:04 PM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Drop brackets are a somewhat point of no return without serious effort. Wouldn't recommend if you already don't know much.
    GreyBaldTaco likes this.
  3. Jan 25, 2020 at 2:10 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Suggest reading in forums: Suspension
  4. Jan 25, 2020 at 2:40 PM
    Local Deluxe
    i know that much.
  5. Jan 25, 2020 at 2:49 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    For the rear, it only gets lifted 4" front goes up 6" so truck sits level.
  6. Jan 25, 2020 at 2:57 PM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    I believe the 2.5 and 2.0 they are referring to is for the diameter of the shock body.
  7. Jan 25, 2020 at 2:59 PM
    Local Deluxe
    Thanks, i have been reading but all the info on there seem kinda vague to me i guess. or maybe i read it too fast. but I've came to the conclusion that with the combination of the adjustable coilovers & the drop brackets new mounting points is what gets you the 6" of lift. Could be wrong. just wasn't sure if the DB contributed to that much lift? assuming the coilover contributes 2.5" of it
  8. Jan 25, 2020 at 3:00 PM
    Local Deluxe
    that makes sense.
  9. Jan 25, 2020 at 3:03 PM
    Local Deluxe
    okay.. i was also thinking that 2.5 may not even have anything to do with the amount of lift but wasn't sure.
  10. Jan 25, 2020 at 3:08 PM
    FuzzysTacos
    Corey
    Wichita, KS
    Correct, shock diameter (/fluid quantity). Long story short, the drop bracket is moving mounting points around. This magic changes the numbers from what a stock truck would receive.
  11. Jan 25, 2020 at 3:13 PM
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    Look real close at what they are saying, You will probably be cutting on cross members to lower the front differential to get it down that low to get a 6" lift in the front.
    Edit: The 2.5 and 2.0 are referring to the shock body diameter.
  12. Jan 25, 2020 at 3:14 PM
    FuzzysTacos
    Corey
    Wichita, KS
    funkeedingus and Ol'gray mare like this.
  13. Jan 25, 2020 at 4:10 PM
    AZF1504x4
    AZF1504x4 Well-Known Member
    That BDS lift is nice you won’t regret it.
  14. Jan 25, 2020 at 4:18 PM
    3pooches
    VA & WV
    o_O
  15. Jan 25, 2020 at 8:20 PM
    FuzzysTacos
    Corey
    Wichita, KS
    You don't believe in magic?
  16. Dec 26, 2020 at 6:12 PM
    Car Ram-Rod
    Car Ram-Rod Well-Known Member
    Anyone know where to purchase fox 2.5 rear shocks with reservoirs for a 6” lift?
    I’ve got the bds 6” coil over kit on order and want to upgrade the rear shocks to match the front 2.5 with resis.
  17. Dec 26, 2020 at 6:29 PM
    Comet'spop
    Comet'spop Well-Known Member
    SanDiego Ca.
    06trd4x4,4dr.longbed Super White
    Buncha shit
    Ive been looking for Fox or King 2.5 to eliminate top spacer in front for some time now, lead times have been from 15-20 weeks,crazy covid crap perhaps or everybody wants the best. Alot can happen between now and then,good luck hunting.
  18. Dec 26, 2020 at 6:36 PM
    Comet'spop
    SanDiego Ca.
    Buncha shit
    The remaining 3.5'' come's from a spacer you bolt to the top of front coilover.
    Myles G likes this.
  19. Dec 26, 2020 at 9:13 PM
    Myles G
    Myles G Well-Known Member
    Myles
    You will use a spacer block as said above
    Fox and King make what they call “full size coil overs” or something similar to that, that are designed longer to where people with DB lifts don’t need to use blocks. I have heard they don’t change ride enough for how much they are.
  20. Dec 27, 2020 at 5:30 AM
    N5J_Taco
    N5J_Taco Well-Known Member
    Several Offroad shops can help you but I went with Marie at HEADSTRONG OFF-ROAD - Low prices and great customer service.
    Edit: I'm only lifted 2 inches but Marie is very knowledgeable on lifts and equipment.
