BDS 820F 6" Coil-Over Suspension Lift Kit + New Wheels + New Rubber
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2020Tacos, Jun 26, 2020.
  1. Jun 26, 2020 at 11:38 AM
    2020Tacos
    2020Tacos [OP] Well-Known Member
    2020 Tacoma TRD Off Road 4x4 Premium
    Coming soon
    Hello,
    I'm kind of torn between a few options regarding the BDS 6" lift, new wheels, and tires.
    The lift kit I'm looking at is the BDS 820F 6" Coil-Over Suspension Lift Kit from Liftkits4less.com, SKU: BDS-820F
    They said the kit would work perfectly with the stock upper control arms, however there is an option to add a "Tacoma Upper Control Arm (UCA) Kit for +699.01.
    What is recommended? To purchase it for that price, source a better recommended UCA for cheaper, or perhaps even just stick with the stock UCA?
    Next, in the kit description it also states that the kit can not be used with 17" wheels.
    Can I not use ANY 17" wheels, or just not the stock +25mm offset's?
    The Max backspacing for this lift kit is 4.5" (-44mm offset), so I'm limited on choosing wheels with a -44mm to -51mm offset.
    Can I use 15", 16" wheels with the correct offset and run 35x12.5's?
    I'm seeing a lot of 20x12 wheels, but i'd like to know what my ranges are with this kit as I'm looking for a durable, light weight, off road wheel, that will work for both all terrain, and mud scenarios. Looking at wheel+tires at customoffset.com website for either 33's or 35's.
    I'm looking for recommendations because I'd like to purchase the lift kit, tires, and wheels at the same time. I'd like to do it right the first time, and not deal with fitment issues considering the overall price-tag.
    Any advice would be greatly appreciated!!
  2. Jun 26, 2020 at 11:53 AM
    waltuo
    waltuo Well-Known Member
    Toyotas
    :popcorn:
    Rockefelluh likes this.
  3. Jun 26, 2020 at 1:11 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
  4. Jun 26, 2020 at 1:19 PM
    FishnTx
    South East Texas
    ‘17 OR
    Pretty sure u can only use 18 inch wheel or above on those types of lifts
  5. Jun 26, 2020 at 1:25 PM
    50TH STATE
    50TH STATE Well-Known Member
    2018 TRD Cement
    Buddy has this lift on his 18 Tacoma with SCS 17” rims and doesn’t have a problem running 33” tires
  6. Jun 26, 2020 at 1:32 PM
    2020Tacos
    Coming soon
    I'm just wanting to really make sure it gets done right in one shot. The delay in shipping because of this COVID thing has caused a nightmare for the carrier services.
    I'm really loving those Ray 10's by SCS....
    @50TH STATE - would you happen to have any pictures of your buddies lift by chance?
  7. Jun 26, 2020 at 1:39 PM
    50TH STATE
    2018 TRD Cement
    I’m pretty sure it’s the backspacing of the factory wheels is the problem as to why they are saying you can’t use 17” wheels. As for the uca did they mention what brand? For that price I would just order camburg uniball UCLA’s with the new cap.
  8. Jun 26, 2020 at 1:44 PM
    2020Tacos
    Coming soon
    well... that's lifted :D
    I'll dig around a little more, hopefully others will chime in i'd like to stick with 18's over 20's to have more tire than rim. Are there any other recommended wheel+tire vendors people purchase from that I may take a look at and compare?
  9. Jun 26, 2020 at 1:45 PM
    2020Tacos
    Coming soon
    They did not mention any brand at all actually so im not sure at all as to what brand or quality the UCA's are.
  10. Jun 26, 2020 at 1:46 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    FYI can’t run 15” wheel. Front brakes too big.
  11. Jun 26, 2020 at 1:47 PM
    2020Tacos
    Coming soon
    Thank you for the clarification on that!! I was looking up specs to see why there aren't many rolling on 15's. This narrows it down a little more!
    Rockefelluh[QUOTED] likes this.
  12. Jun 26, 2020 at 1:50 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    You are aware that this lift kit is going to destroy offroad performance, and be extremely hard to undo, right?
  13. Jun 26, 2020 at 1:53 PM
    2020Tacos
    Coming soon
    I'm researching as much as I can - and maybe my sources have informed me with incorrect information (there job is to sell the products).. - Can you explain why it would, and what you'd recommend by chance?
  14. Jun 26, 2020 at 1:58 PM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    It cuts out the factory crossmembers and bolts in new ones. It's known as a drop bracket lift kit. The only way to revert from these is to hire a welder to weld the crossmembers back in.
    As to performance, they weld in steering stops which increases your turn radius, these trucks are already at the upper limit of maneuverability for a lot of trails. It lowers the front diff which can also cause problems, you can look that up on this site where people have had full 3/16 or 1/4" skid plates with a diff drop installed and ended up destroying the diffs.
    The recommendation is to go with a true 2-3" suspension lift and leave it at that. Bigger tires will simply require cutting plastic/tubbing the firewall, a cab mount chop, and/or a body lift.
    2020Tacos[QUOTED][OP] likes this.
  15. Jun 26, 2020 at 2:05 PM
    2020Tacos
    Coming soon
    I was aware of the difficulties in reverting it back, which most people tend not to. I can only guess that its going to cost an arm and a leg.
    The dif drop I understand, but doesn't the lift counter that? I was way off in my understanding of it thinking it'd be plenty of leeway for off road if thats not the case!
    not looking to replace a dif any time soon, so your comment has me re-thinking the whole project now..
    Also I read recently that the trd off road already has a 1in lift factory, so a true 3 in lift would only gain us 2 more inches, is this fact?
  16. Jun 26, 2020 at 2:08 PM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Roughly, most higher end coilovers are adjustable. I run just shy of 3" true lift with mine.
  17. Jun 26, 2020 at 2:10 PM
    jcm
    jcm Well-Known Member
    2017 TRD-OR 6M
    I'd suggest practicing patience and doing more research. If you want a monster truck to drive around town, this will do the trick. If you want to improve off road performance, pick a good 2"-3" lift.
  18. Jun 26, 2020 at 2:12 PM
    2020Tacos
    Coming soon
    I'm not as familiar with suspension lifts & body lifts as some of the others on here and only know 2 reuputable brands, them being pro comp and bds. as far as coil overs go, I'm not familiar all with.
    are there any complete kits or seperate kits that are recommended for 33's or 35's. I need to do some more homework and comparisons it looks like.
  19. Jun 26, 2020 at 2:15 PM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    King, Icon, ADS, Fox are all reputable high end adjustable coilovers. I personally run ADS with OME leafs. As I run 255/85r16 (skinny 33s) I didn't even need a cab mount chop. I've got my coilovers cranked down pretty hard because of the weight I have up front though.
    35s will be significantly more work. There are threads on here that detail it.
  20. Jun 26, 2020 at 2:17 PM
    2020Tacos
    Coming soon
    Patience I do have a lot of - It's been quite a while since I've looked into the off road options, as its been nearly 10 years since my previous Tacoma was murdered and ransacked by thieves after I relocated.
    The intention with the build I'm looking for is overland + off road trails with other taco's and groups of friends. A show like monster truck would be suitable but not the for my purposes.
