BDS and RCD lift questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ccrames2018, Mar 7, 2018.
  1. Mar 7, 2018 at 9:15 AM
    Ccrames2018
    Ccrames2018 [OP] Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    Hi all, came from a Tundra that was totaled and looking for a Tacoma (either 2nd or 3rd gen) now. I know there are lots of threads on this topic but I keep finding conflicting information. From those of you that actually have a 4 inch bds lift and have tried 17x9 wheels, did they fit? I know BDS says no. Im looking at a 4 inch bds, 17x9 -12 offset, and 305/65R17 tires. All I want to know is whether they will fit with the lift knuckle or not. From what I've seen there are a couple guys running them but I want to make sure before I decide once I get a Tacoma. Thanks for your time!
  2. Mar 7, 2018 at 12:25 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Skip the bds kit and think about a good set of coilovers and a full leaf pack. You will thank yourself later
    Mully likes this.
  3. Mar 8, 2018 at 8:34 AM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    So I see that the RCD lift comes with longer Bilstein coilovers instead of the spacer in the BDS. It's also more expensive. Also I would probably swap the blocks for an AAL if I got this kit. Any preferences between the two for those of you who have used them? It also looks like you can use a 17 inch wheel with that one too which is nice. I would go with C/Os but I want a bit more than 3 inches of lift and don't want CV or diff problems which the DB seems to take care of.
  4. Mar 8, 2018 at 11:08 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Are you looking at 2wd or 4w4? If 2wd . Look a lift spindles and Dakar leaf springs, Bilsteins
    desertrunner24 likes this.
  5. Mar 8, 2018 at 11:14 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Drop bracket lifts bend. Lift with coilovers, cut, trim, BFH, CMC, 35s. You will love it.
  6. Mar 8, 2018 at 11:14 AM
    Mully
    CA
    By the way. Welcome.
  7. Mar 8, 2018 at 1:45 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    I'm going 4wd. What's BFH stand for? Big Fat Hammer for a pinch weld or something?
  8. Mar 8, 2018 at 1:46 PM
    Mully
    CA
    That or Big Fu**ing hammer. Lol.
  9. Mar 8, 2018 at 2:43 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Haha thought so
  10. Mar 8, 2018 at 2:50 PM
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I'm running 17x9 with my RCD if that helps. The kit is 5" front and 4" rear. It comes with front shocks, not coilovers. They used to have a Fox Shock upgrade available, but when I inquired about it a year ago, they said it's not longer an option.
  11. Mar 9, 2018 at 5:36 AM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    You know, after some more research, I think I'm going to stick with 3" and under. I don't want to lose so much power going with the 305s. Also the DB lifts are pretty much permanent, so I would hate to get that and regret it. Thanks for the help guys!
  12. Mar 9, 2018 at 5:50 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Smart choice :thumbsup:
