BDS lift axle wrap
Discussion in 'Hawaii' started by Car Ram-Rod, Jan 15, 2021.
  1. Jan 16, 2021 at 7:49 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    That's not axle wrap then. Like I said, 2 entirely different causes and remedies. Axle wrap will be only under hard acceleration and you wouldn't feel it with mellow driving or under braking conditions. Even the remedy you are looking at wouldn't fix actual axle wrap, it's the fix for bad angles. You are lowering your carrier bearing thereby creating less of an angle at the Ujoints. What degree is the pinion mount at and the degree of the driveshaft? Chances are you are probably at -3 degrees or higher with that lift. the blocks tend to only have enough degrees for the amount of lift that block lifts which is often simplified as 1 degree per inch of lift. If you have a HD set of springs in there then youre probably at around 6 inches of lift but only enough angle for 3 inches of lift. Personally I'd start with a 3 degree shim under the blocks. Measure you're angles first though to know you're starting point
  2. Jan 16, 2021 at 7:52 PM
    Car Ram-Rod
    Car Ram-Rod [OP] Well-Known Member
    The vibration is under hard acceleration from stop.
  3. Jan 16, 2021 at 7:53 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Good luck with that pal. Lmfao. I’m out.
  4. Jan 16, 2021 at 7:59 PM
    inksin
    Hawaii
    You said you have vibration on deceleration too
  5. Jan 16, 2021 at 7:59 PM
    Car Ram-Rod
    Thanks. Appreciate the help
  6. Jan 16, 2021 at 8:00 PM
    Car Ram-Rod
    Yes.
  7. Jan 16, 2021 at 8:01 PM
    inksin
    Hawaii
    Then I can guarantee it's not axle wrap.
    Measure you're pinion and driveshaft angles and you'll find the problem
  8. Jan 16, 2021 at 8:02 PM
    Car Ram-Rod
    Alright. Thanks for the help
