BDS Suspension
Discussion in 'Suspension' started by Laroche33, May 15, 2013.
  1. May 15, 2013 at 7:31 PM
    Laroche33
    Laroche33 [OP] Active Member
    Massachusetts
    05 TRD Off Road
    2.5" lift in front, 2" aal in back
    Is there anyone out there running the 6in coil over lift from BDS? Really considering going with that lift kit. Just curious about some pros and cons about the lift. Thanks!
  2. May 15, 2013 at 7:32 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    Pretty much all DB lifts are similar
  3. May 15, 2013 at 7:35 PM
    Laroche33
    Massachusetts
    05 TRD Off Road
    what do you mean?
  4. May 15, 2013 at 11:46 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    All three 6" drop bracket style lifts are similar in design, and performance. The one thing that sets BDS apart from the rest is the option of buying the kit with Fox Coil overs and shocks. BDS also includes a slightly larger skid.
    They do differ with the method of lifting the rear through. Pro Comp and Fabtech include an add a leaf and block. BDS uses a lift block only.
    My suggestion for any of the 6" kits is buy stainless steel extended brake lines from the get go, makes for a cleaner install by ditching the brake line spacers. PM OCtaco for a good deal on front/rear sets.
  5. May 19, 2013 at 8:55 PM
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
    Question for y'all.my tacoma's sitting on a 3' bilstein w/ 5100's.20 inch moot metals wrapped with 33 inch toyo's.its a smooth ride.,but i want a little more height.if i go with the bds coilover lift(fox shocks)..think it's going to be a stiffer ride?thought about the regular 6 inch lift from bds.asked the guy at the shop if there was a big difference in ride quality between the two.he said "it's a night and day difference"(but he also is the owner of the shop.the coilover lift is also about 1500$ more..that a pretty big profit difference if you ask me)
    So I'm asking you all.what would y'all do?
