Be proud of me. FINALLY took the lift plunge!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KDOG, Feb 11, 2015.
  1. Feb 11, 2015 at 2:54 PM
    KDOG
    KDOG [OP] Well-Known Member
    Belleplain, NJ
    Bilsteins, OME 884s, 3 stage progressive AALs.
    After going back and forth, asking a thousand dumb questions, driving other TW members crazy with my indecisiveness, I finally just said "screw it" and pulled the trigger. Here's what's on the way from Wheelers Off Road.
    Front Bilsteins (adjustable)
    Rear Bilsteins
    OME 884 coils
    1.5" 3 leaf progessive AALs
    Whaddya think? Go easy, I'm a virgin.
  2. Feb 11, 2015 at 5:29 PM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I've been looking at doing the same setup but with 885 springs. I am wondering if UCA need done at the same time.
  3. Feb 11, 2015 at 5:34 PM
    KDOG
    Belleplain, NJ
    Whoa no one said anything about having to swap uca's....is that necessary for a barely 2 inch lift?
  4. Feb 11, 2015 at 5:40 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    What are you going to set the fronts at?
  5. Feb 11, 2015 at 6:17 PM
    toomanytoys84
    Stock
    I am confused. Looking at the same setup at headstrong and they call it 2.5 to 3 inch lift.
    Are they exaggerating their lift?
  6. Feb 11, 2015 at 6:20 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Depending on what ring you set it on.....they're adjustable from 1" to 2.5". They have 4 setting on them. Then if you add stock coils you will get the lift of the ring you out it on, or with the Eibechs you get around another 1.5" or so.
  7. Feb 11, 2015 at 6:23 PM
    KDOG
    Belleplain, NJ
    They said with the coils I can set the fronts to 0 since the new coils will add about 2" by themselves.
  8. Feb 11, 2015 at 6:41 PM
    KDOG
    Belleplain, NJ
    Cool. I have a DCSB 4x4 V6 too. That's about perfect. With the 1.5" lift in the rear with the AALs, it should still keep most of that front down rake that I wanted to keep.
  9. Feb 11, 2015 at 6:46 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I'm thinking about this same lift + spacer.
  10. Feb 11, 2015 at 6:50 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    grats, did the same myself a few years ago. best truck mod ever imo.
  11. Feb 11, 2015 at 7:03 PM
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    Love the setup. Get a UCA ;)
  12. Feb 11, 2015 at 7:05 PM
    KDOG
    Belleplain, NJ
    I heard it will settle after a bit though.
  13. Feb 11, 2015 at 7:36 PM
    MadDaddy
    Many & varied
    I meant the lean spacer, not those other godforsaken things :)
