Beach maintenance
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nebular, Jan 19, 2025.
  1. Jan 19, 2025 at 2:17 PM
    Nebular
    Nebular [OP] Member
    I'm looking to buy a Tacoma soon for beach/work. This vehicle will be driven on sand fairly often. What I plan on doing was spraying the under carriage after each trip and then drying it with a horizontal fan. Does anyone advise against this? I do not want to undercoat as I think this will be more harmful to me than good. Any advice on what to do for extra maintenance?
  2. Feb 6, 2025 at 8:32 AM
    Jsevert2023
    Jsevert2023 Toyota service writer
    Jonathan
    Eastern Pennsylvania
    Gen 3 SR 4x4 4cyl AC, 2018 rav4
    I like to sleep in my truck.
    Just undercarriage wash regularly
    Chew, BoomerGVNG and ToyoTaco25 like this.
  3. Feb 6, 2025 at 8:57 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I made this to spray mine off after beach driving.
  4. Feb 6, 2025 at 9:07 AM
    Jsevert2023
    Jonathan
  5. Feb 6, 2025 at 9:09 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I'd apply Fluid Film all over under the truck (to a clean and dry undercarriage).
    That always-soft DIY spray coating is difficult to wash off and provides terrific protection. Dust and small dirt will sorta stick to it, but that won't cause any problems unless you brush up against the protected areas.
    There are hundreds of threads on here talking about Fluid Film and similar lanolin-based anticorrosive treatments. Probably the biggest downside of FF is its smell. A lot of people find it revolting. I have a dull nose and can barely smell it...
    Chew likes this.
  6. Feb 6, 2025 at 9:17 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    driving on the beach does not do the damage most people say it does. It's dry.
    The problem of rust is mainly contributed to roads that are salted in the winter.
    source: been driving on the beach for 20 years. only undercarriage rinse in the winter due to salt. rust has never been a problem for me.
    I dislike all these undercarriage coatings. they make it a mess when you need to do maintenance and mask any drips or leaks you have. juice is not worth the squeeze imo.
  7. Feb 6, 2025 at 12:53 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Maybe spray with clean water with one of those long handle watering things that gardeners use. I wouldn't bother drying.
    Barsoom likes this.
  8. Feb 6, 2025 at 1:07 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  9. Feb 6, 2025 at 1:10 PM
    RIX TUX
    or put a sprinkler on the driveway and drive over it
  10. Feb 6, 2025 at 1:20 PM
    joebwan
    joebwan Active Member
    2017 TRD OR White & 2017 TRD Pro Cement
    I live on the beach and am in sand and salt water pretty often. I did a Fluid Film total coverage underneath before it got here and do a light power wash once a month, and reapply Fluid Film every six months. Zero corrosion. Be sure to get inside the frame holes with FF.
  11. Feb 6, 2025 at 1:43 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Note that water causes rust, not salt. Salty water is however worse than water alone. You could be making things worse by adding water to the equation. Albeit I do not know of any scientific evidence supporting that or vice versa.
    You should also realize that painted metal does not rust regardless of salt water. There needs to be some imperfection/damage in the paint for the water to get access to the steel underneath.
    Typically the rust starting points are in places you cannot see, eg inside the body or frame. Salty water can collect in these places and remain moist for long periods of time. This is why the body and frame have drain holes. Your time might be better spent making sure none of your drain holes are plugged.
    Personally, I would have to have a lot of extra time on my hand to bother washing my truck after driving on the beach.
    My best personal experience with rust on a modern vehicle is my 2001 Subaru which I owned until 2015. I rarely washed it, never used any rust treatment, drove it through 15 Minnesota winters, and the only serious rust was inside the windshield seam and the roof rack. I blame the windshield seam rust on a shoddy windshield replacement.
  12. Feb 6, 2025 at 1:46 PM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    This works great for cleaning underneath
    majpooper and RIX TUX[QUOTED] like this.
  13. Feb 6, 2025 at 2:26 PM
    Jsevert2023
    Jonathan
    RIX TUX likes this.
  14. Feb 6, 2025 at 2:31 PM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    This is exactly what I’ve done for years. I usually park in the grass so everything falls on the lawn and not on the concrete driveway. But it has worked for me.
  15. Feb 6, 2025 at 2:32 PM
    Jsevert2023
    Jonathan
    I'm going to bring mine to work tomorrow and do that. Just genius.
  16. Feb 6, 2025 at 5:59 PM
    wood714
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    As long as you stay on dry sand there should never be a problem.
    The bone heads that drive down to the water are the ones with rusted out frames.
  17. Feb 7, 2025 at 5:47 AM
    BoomerGVNG
    long island
    2022 TRD SPORT DCSB
    oh i see lots of people total their beach rigs out here in the break...usually young girls in Wranglers or boys in their daddies F350 Superduty :D
    Jsevert2023 and wood714[QUOTED] like this.
  18. Feb 7, 2025 at 6:03 PM
    delz05
    delz05 Well-Known Member
    try Woolwax, a very slight smell out of the bottle, no lingering smells at all... seems to resist "wash off" better than FF...
    usmc2msu likes this.
  19. Feb 8, 2025 at 4:59 PM
    Eldorko
    Eldorko Member
    I’d advice you to quit, beach/work sounds like a horrible occupation.
    Phlogiston likes this.
  20. Feb 8, 2025 at 5:36 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    In Texas you can drive on the Beach. They have undercarriage washes that most people who live by the Beach use religiously. BTW
    gudujarlson[QUOTED] likes this.
