Beach Tire Pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TicoTRD, May 9, 2013.
  1. May 9, 2013 at 1:41 PM
    TicoTRD
    TicoTRD [OP] Well-Known Member
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    Ive searched for this and came up empty, but what is an acceptable tire pressure for a dcsb on stock wheels and tires? thanks in advance
  2. May 9, 2013 at 1:50 PM
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    Last few times on a beach I haven't bothered airing down or using 4wd.
  3. May 9, 2013 at 1:53 PM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    well if thts ur truck in your sig...u have better tires than me...
  4. May 9, 2013 at 5:20 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    What Tires ???
    :D
  5. May 9, 2013 at 5:23 PM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    I'd go about 20. you should be safe there and not be close to breaking the bead. Al depends on the weight of the vehicle and how soft/packed the sand is. Under 15 mixed with crazy driving can pop the bead off.
  6. May 9, 2013 at 5:29 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I also agree that around 20 is a fair compromise with stock tires. that's what I usually run off-road. whether sand, snow, rocks, whatevs
  7. May 9, 2013 at 9:01 PM
    knotty
    knotty Well-Known Member
    milwaukie, oregon
    i dont air down at all ... never had to worry as long as you keep moving and when you come to a stop dont just hammer the gas .. the key is to try and stay on top of the sand !
  8. May 9, 2013 at 9:15 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    M/T is no better in sand than a street tire.
    20PSI is good. Depends on how packed the sand is and what kind of tires your running.
  9. May 10, 2013 at 4:35 AM
    ANT2013taco
    ANT2013taco Well-Known Member
    McAllen Texas
    13 TRD OR 4wd
    I wouldn't go down more than 5psi at a time, find the perfect setting for where you are. 20psi would definitely be the lowest though.
    Do yourself a favor, carry a shovel, tow rope and small compressor.
  10. May 10, 2013 at 4:36 AM
    jandrews
    '09 FourDubDee TRD OR
    Low.
    If that doesn't work: Lower.
  11. May 10, 2013 at 4:56 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    With a P-metric tire i dont think it really matters all that much. The side walls are soft enough that the tire sits pretty fat anyhow, compared to a LT tire. I havnt ever had a problem either. But definately agree, folding military shovel, good tow strap, small compressor to inflate if you do air down, good tire guage. Never leave home without them.
  12. May 10, 2013 at 5:44 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    ok thanks for the input guys.
  13. May 10, 2013 at 2:19 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Off topic a little but should I take my stock mud flaps off when driving on the beach? If you lower your pressure to 20psi how much lower will my truck be?
  14. May 10, 2013 at 2:45 PM
    jandrews
    If I lower my pressure to 20psi your truck will still be the same height.
  15. May 10, 2013 at 2:52 PM
    ANT2013taco
    McAllen Texas
    13 TRD OR 4wd
    Not much, but once you start running into ruts you will be a bit lower, depending on the rut itself. Not much different than running in mud, different consistency though.
  16. May 10, 2013 at 2:59 PM
    clc clc
    PA
    so would it be a good idea to remove em? I plan on driving assateague this fall and don't want to rip my flaps off.
  17. May 10, 2013 at 3:10 PM
    ANT2013taco
    McAllen Texas
    13 TRD OR 4wd
    It wouldn't hurt to, it's really driver preference. If you go into deep ruts then its a good idea to remove them while you are off road.
  18. May 10, 2013 at 3:48 PM
    clc clc
    PA
    Another off topic question. Besides power washing the undercarriage and frame anything else I should do after beach driving? I live in Pa so its not like my truck is salt free.
  19. May 10, 2013 at 3:55 PM
    ANT2013taco
    McAllen Texas
    13 TRD OR 4wd
    Buy some Salt Away, it works well.
  20. May 10, 2013 at 3:57 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
