Beadlock Bolt Size
Discussion in 'Wheels & Tires' started by Goose8651, Mar 10, 2015.
  1. Mar 10, 2015 at 7:41 PM
    Goose8651
    Goose8651 [OP] Well-Known Member
    DFW
    2013 Double Cab
    Does anyone know the bolt size for the beadlock ring on the Baja style TRD wheels?
  2. Mar 11, 2015 at 10:03 AM
    CoYota970
    CoYota970 Member
    Will
    St. Paul, MN
    2013 Toyota Tacoma TRD TX Pro Baja
    Front window tint, stubby antenna, matching white grill
    T-30 Torx M8 x 1.0? I've found two part numbers for these:
    PTR18-35093
    PTR45-34073
    Expensive lil buggers if you go OEM. I stripped two of mine when taking the rings off so I've been looking at options.
  3. Mar 11, 2015 at 10:33 AM
    Goose8651
    DFW
    2013 Double Cab
    This helps a bunch, thanks. I was hoping I could find a set possibly in black at a mom and pop hardware store. Don't want to have to paint them. Thanks for the help.
  4. Mar 11, 2015 at 10:38 AM
    Goose8651
    DFW
    2013 Double Cab
    I just got on Amazon and used the product code you referenced. It looks like they come in a quantity of 12 and the size is T-30 Torx M8 x 1.0. Thanks again for the help in the part number.
  5. Mar 11, 2015 at 7:21 PM
    CoYota970
    CoYota970 Member
    Will
    St. Paul, MN
    Not a problem. Happy to help.
  6. Jan 1, 2018 at 8:50 PM
    ATOMZ
    ATOMZ Well-Known Member
    Adam
    Cascadia
    2005 Tacoma TRD off-road
    A 2005 rebuilder with a 2015 facelift.
    Thread revival. Curious if you were ever able to find some black replacement torx’s for those wheels? Thanks in advance!
  7. Jan 19, 2019 at 5:51 AM
    Goose8651
    DFW
    2013 Double Cab
    I just bought them off of Amazon and painted them black.
  8. Oct 12, 2021 at 11:20 AM
    Hunter_Bick12
    Hunter_Bick12 Just a Yota guy
    Hunter
    Alabama
    2011 Black DCSB TX TRD Prerunner, 1986 Gray SR5 4x4
    Thread revival again.. could you look back through your orders and find me the link you used on Amazon? I need a replacement and I’m not finding it using the part numbers above. Thanks!
