Bearing F*** Job
Discussion in 'Technical Chat' started by drew02a, Aug 18, 2009.
  1. Aug 19, 2009 at 8:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :D
  2. Aug 19, 2009 at 11:13 AM
    drew02a
    drew02a [OP] Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Now you can both tell your buddies about this other dude you know who ran without his and the hub separated whilst he was driving down the road minding his own business. :cool:
  3. Aug 19, 2009 at 11:18 AM
    drew02a
    San Antonio, TX
    Maybe I should just go ahead and SAS so I don't have to worry about it again? :D
  4. Aug 22, 2009 at 1:33 PM
    drew02a
    San Antonio, TX
    Okay, I finally went and jacked up the truck so I could take the wheels off and see what was going on in there. I noticed these on the ground and wondered for a second what they were
    Then I looked behind the hub
    The only thing holding the hub on was the brake disc catching on the caliper :eek::eek::eek:!
    Here are some tire shavings from rubbing the spindle
    And the tire Damage
    Thank goodness for Discount Tire's road hazzard tire replacement, huh?
  5. Aug 22, 2009 at 1:47 PM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2016 4Runner
    Note to self - Do not drive truck without front axles.
  6. Aug 22, 2009 at 2:07 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Drew02a,
    Sorry you had to "Teach" us this lesson BUT we all should see from your photos( great pix) that you should NOT do this.....
    That being said,you are very lucky...go play a "lotto" number...the truck and yourself made it home....
    Snoope
  7. Aug 22, 2009 at 2:09 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2.
    Hope you get everything back to normal Drew.
  8. Aug 24, 2009 at 9:41 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Damn. That wheel bearing doesn't look very pretty..
    If you haven't had the new bearings installed yet, and need them pressed in let me know. I am taking a trip to the mechanics either tomorrow or Wednesday and can have them pressed in for free. If I remember correctly, those wheel bearing are about 100 bucks a piece at the dealer. You can take the bearing number and cross reference it across nearly all bearing manufactures. I would highly recommend a Timken replacement if not going with the factory bearings.
  9. Aug 24, 2009 at 9:45 AM
    drew02a
    San Antonio, TX
    It looks like the bearings I got are already pre-assembled on a hub so I might be able to dodge the whole bearing press thing all together. I'll be taking the whole thing apart this evening and making sure, though. If it requires the use of a press I'll let you know.
  10. Aug 24, 2009 at 9:48 AM
    SC4333
    Grant
    FL
    Hell, you cant beat that. If for whatever reason you do need a press, just let me know.
  11. Aug 24, 2009 at 9:53 AM
    drew02a
    San Antonio, TX
    Wildo
  12. Sep 19, 2009 at 5:24 PM
    drew02a
    San Antonio, TX
    Well it's been almost exactly one month since the inceident and $250 later the truck is finally drivable again. I replaced the bearings and seals.
    It turns out that the heat generated from the friction melted my ABS sensonrs and warped my rotors a bit. I'll need to replace those soon, but at least I'm able to drive the truck again now.
    Took it for a test drive and almost got stuck in the mud, even with both lockers engaged. Time for some Mud Terrains.
