bearing or grinding noise at high speed deceleration
Discussion in '4 Cylinder' started by approach, Nov 20, 2009.
  1. Nov 20, 2009 at 3:20 PM
    approach
    approach [OP] Active Member
    jason
    oklahoma city
    05 tacoma
    i have searched the forum for this and found some stuff. but i dont have the clunking noise that most say. when i decelerate in 3.4.5th gear it sounds like a bearing is grinding or loose, all most like its spinning. any ideas. a lot of the threads i found close to this problem, none had seemed to solve them. any help would be great. thx
  2. Nov 20, 2009 at 4:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    From where are you hearing the sound?
  3. Nov 20, 2009 at 4:09 PM
    approach
    jason
    oklahoma city
    05 tacoma
    it sounds close to under the middle to front of the cab centered.
  4. Nov 20, 2009 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm....Im guessing the tranny.....When was the last time the fluid was changed?
  5. Nov 20, 2009 at 4:12 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    could the u joint be gone, what speed does it happen
  6. Nov 20, 2009 at 4:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure a bad joint would make a grinding sound.....It could, but I havent heard it like that....
  7. Nov 20, 2009 at 4:34 PM
    approach
    jason
    oklahoma city
    05 tacoma
    it happens around 50 and above. it has the ome coil overs and leaf springs. looks to be a few inches taller than stock. thought it might be from the angle change. this a new truck to me. its a 2005 reg cab 5 speed man. it has 28000 miles on it.
  8. Nov 20, 2009 at 4:35 PM
    approach
    jason
    oklahoma city
    05 tacoma
  9. Nov 20, 2009 at 4:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm......Sounds like it could be the tranny. Only in gears 3, 4 and 5?
  10. Nov 20, 2009 at 4:53 PM
    approach
    jason
    oklahoma city
    05 tacoma
    so far thats all i have noticed. i went under and looked at the drive shaft, the u joints dont have play in them . i could turn the shaft about a .25in. just kinda weird. as soon as i give it some gas it goes away. let off and its there.
  11. Nov 20, 2009 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Change the fluid and see if that does anything.
  12. Nov 20, 2009 at 6:36 PM
    approach
    jason
    oklahoma city
    05 tacoma
    change the fluid in the....... transfer case???
  13. Nov 20, 2009 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would say trans, tranny, and diffs, but Im thinking this should be covered by the 60k powertrain warranty....It might be a good idea to take it in to the dealer.
  14. Nov 20, 2009 at 7:00 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I have the same noise and haven't been able to figure it out yet. I removed the read drive shaft and drove it as front wheel drive and it got rid of the sound, so it's not the tranny. Maybe something is loose in the transfer case.
  15. Nov 21, 2009 at 7:52 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    This noise has been covered. Take your foot off the gas at freeway speeds, makes noise, then it goes away when you slow down to about 50 MPH (mine goes away at 50MPH also). Give me a minute and I will find the thread. I asked the same question and there is susspoisdly a TSB for it but from what I've heard doesnt do much if any good.
    EDIT:
    Here is the thread I started about it. There is another one on it too. I'll see if i can find it.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/38067-deceleration-noise-freeway-speeds.html
  16. Nov 21, 2009 at 6:04 PM
    approach
    jason
    oklahoma city
    05 tacoma
    well left oklahoma city this morn at 430am to drive to lawrence ks to pick up my shell. averaged 16.5 mpg. not what i expected. best i did with a gas treatment was a little over 17mpg. would like to get better than that. so i will start looking to see what i can do. i dont think the arb bumper weighs that much. running 265/ 75/ 16 bfg ats. anyone running close to this set up and getting better mpg?
    well the noise is still there. its wild how giving it gas makes it go away. it feels like something is either not fully engaging or disengaging. cant tell. its at high speeds. i would like to find out what is going on. i read the thread that was posted. is this the final answer?
    "The TSB states, remove and replace Rear Differential. Toyota carriers are setup as a completly assembled ring and pinon. If the gears howl during deceleration only, it’s possible that the pinion-bearing preload has loosened or the pinion / carrier bearings are damaged
  17. Nov 21, 2009 at 6:11 PM
    approach
    jason
    oklahoma city
    05 tacoma
    cause mine doesnt sound like its in the rear at all. heres a pic of the shell for $100 is is a nice ARE shell, needs paint. but everything works great and is real nice. thx for the info on the shell.
  18. Nov 21, 2009 at 6:12 PM
    drew02a
    San Antonio, TX
    I changed my diff to ARB and it still makes the noise.
  19. Nov 22, 2009 at 6:30 AM
    chad68
    Chad
    My noise sounded like it was coming from in between the bed and cab.
  20. Nov 22, 2009 at 9:58 AM
    approach
    jason
    oklahoma city
    05 tacoma
    so no one has figured this out yet? i thought for sure someone had a solution. i guess i will take it to my mech friends and see what they say. i bought my truck used, is the 60k powertrain warranty still good on a used truck. i only have 29k on it.
