Bears Ears and Windows
Discussion in 'Off-Roading & Trails' started by Dirty Pool, Oct 30, 2016.
  1. Sep 29, 2018 at 10:49 AM
    #61
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
  2. Mar 12, 2019 at 10:44 AM
    #62
    Dirty Pool
    Dirty Pool [OP] FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Couple of "Biguns" (Al Bundy speak), some lithic tool flakes and a dino Gastrolith for good measure. The textured pieces are attributed to the Anasazi.
    wilcam47 and License2Ill like this.
  3. Jul 27, 2019 at 11:27 AM
    #63
    Dirty Pool
    99 XCAB V6 MT TRD
    Looks like some hanky panky going on with the original plan for the Monument.
    Originally the only change to the area was prohibitions to commercial development, resource extraction etc.
    A new "plan" has been developed that involves "some" closures to OHV routes, mostly access to delicate cultural sites.
    It looks to me like some administrative ploy to appease part of the opposition that feels the original plan (monument designation) did not go far enough.
    The local paper here just ran a story claiming several hundred miles of OHV routes would be closed. My quick initial research on various NPS/BLM sites looks more like some hiking trails that have been abused by ATV's are getting the attention as opposed to established 4x4 vehicle routes. Exact details like closure lists/maps are proving hard to find at this early point.
    Wishbone Runner likes this.
  4. Jul 27, 2019 at 1:01 PM
    #64
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Slight derailment, but have you heard anything on the Swell, Mr. Pool?
    I heard similar news about a bunch of trails being closed out that way before I went there this spring, but haven't heard much since.
  5. Jul 27, 2019 at 3:45 PM
    #65
    Dirty Pool
    99 XCAB V6 MT TRD
    Haven't heard about anything in particular. However it's a big place and the odd gate has been closing here and there for a while.
  6. Jul 30, 2019 at 12:15 PM
    #66
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
