Beat That Dead Horse!!!
Discussion in 'Suspension' started by Benson X, Feb 24, 2011.
  1. Feb 24, 2011 at 2:49 PM
    Benson X
    Benson X [OP] ...and we're back!
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I will be ordering the OME (885's) 3" Kit w/ LR UCA's. I will eventually be getting these <TIRES (5272)> with these <WHEELS.> Will I need any of the following components to ensure proper safety/durability/no rubbing/no vibes/alignment? I just want to make sure I have EVERYTHING so I can do the install all at once.
    (these are ALL hyperlinks)
    SWAYBAR RELOCATE
    DIFF. DROP KIT
    AXLE SHIMS
    TOP SPACER SET (I might need the full 3" with those wheels/tires)
    SINGLE SPACER (Instead of the OME trim packers)
    I have a 2011 TRD Sport 4x4 DC/LB
    I posted a similar question in another thread, but no response, plus it was a GB thread for Metaltech4x4, and I didn't want to hijack it. Thanks in advance for the answers/advice/experience/smartass comments etc.;)
  2. Feb 24, 2011 at 3:06 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    the top plate spacer will give you the full 3" lift. The diff drop is hit or miss. Most will reccomend not doing it. The axles shims or carrier bearing drop are necessary if you have vibrations after the lift is installed. Do you have a 4x4
  3. Feb 24, 2011 at 3:15 PM
    cc350
    cc350 Retired Member
  4. Feb 24, 2011 at 4:15 PM
    Sprink669
    Sprink669 Well-Known Member
    I have OME 886 springs with dakar leafs and I have vibes at about 20-30 then it goes away. I have the OME carrier bearing drop, diff drop, sway bar relocate block, and I just ordered beefedtaco's carrier bearing drop. Good luck!
  5. Feb 24, 2011 at 4:31 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    There is only one way to ensure no vibes... don't lift your truck. that being said a carrier bearing drop or shims will help. I am not sure why someone said no diff drop, but its a good idea to help with CV angles. No sway bar relocate needed for OMEs.
  6. Feb 24, 2011 at 5:54 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I'm tempted to just get everything listed and play it safe. I just don't want to spend the extra $160 if I don't need to, but if I do end up needing it, it will be worth it.
  7. Feb 24, 2011 at 6:11 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Some 2nd genners have issues with the diff drop some don't. Play it safe and if it doesn't help sell it
  8. Feb 24, 2011 at 6:18 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    They make a difference on cv angles for first gens, but they don't really do much for second gens. Someone did the math and showed it changed the angles less than 1 degree.
  9. Feb 25, 2011 at 2:30 AM
    Sprink669
    I needed a swaybar relocate bracket and I have the OME 886 springs. OME says that it is not recommended but I needed one and have read past posts about others needing the bracket. :eek:
  10. Feb 25, 2011 at 9:28 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
  11. Feb 25, 2011 at 9:35 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  12. Feb 25, 2011 at 12:34 PM
    Valley Viking
    Valley Viking Well-Known Member
    Menlo, WA
    05 4x4 DC LB SR5
    OME 885 Coils, OME Dakar Rear Leafs, OME NitroCharger Shocks, LR UCA's, AFE ProDry Air Filter, Scanguage, Wet Okole Seat Covers
    Get the OME trim pack. It goes on the bottom of the coil at the spring seat. You don't want to stack spacers on top of your coil pack. I would recommend the smallest top spacers you can get. I just installed the OME 885's on my truck with the 10mm top spacer from Wheeler's Offroad and it gave me 3.5" of lift in the front. It's pushing the limits on CV angles.
  13. Feb 25, 2011 at 12:39 PM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    Take your swaybar off!
