beating a dead horse... or trans
Discussion in '1st Gen. Tacomas (1995-2004)' started by facemob, Oct 22, 2010.
  1. Oct 22, 2010 at 8:14 PM
    facemob
    facemob [OP] Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    so.... i have read and researched.... I have talked, and i have listened.......I have searched this site and others......i have exhausted my resources.......the question.......can and does, gl-5 gear oil, such as any that can be found on your local auto parts dealers shelves (including mobil 1 75w 90 which admits it can be harmful) .....harm yellow metals in transmission such as the trans in my 2003 5vz with the 5 sp r150 trans. by nature gl5 oil, from what i understand (i claim to be no scientist), removes impurities from metals and suspends the impurities in the oil, thus doing its job, but with yellow or softer metals, it continuiously strips the metals in the process. is this true of false ? we are talking gl5 in a manual trans, good? bad,? or doesnt matter as long as you dont drain it again and look at the metal flakes? any final answers to this question would be awesome
  2. Oct 22, 2010 at 9:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to TW. Hope you get a clear answer to your question...
    X
    X
    X
    Here is a free bump!
  3. Oct 23, 2010 at 6:31 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i have heard from numerous people here on TW that GL-5 trans fluid is harmful to the syncros in the trans so id stay clear off any fluid that is GL-5. instead go with GL-4.
