Beating your pinch weld flat with a sledge hammer. --Let's discuss!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Apr 6, 2016.
  1. Dec 17, 2020 at 10:21 AM
    #261
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    No rubbing for my use. The liners are flat surfaced vs the stock’s ridges, so it does provide a touch better clearance. I also trimmed the bottom corners of the flares, good alignment with high caster to aid
    zharv[QUOTED] likes this.
  2. Dec 17, 2020 at 10:43 AM
    #262
    zharv
    zharv Well-Known Member
    Zach
    MT
    2013 Black TRD OR AC
    Sounds like my truck. You might have me convinced.
  3. Dec 17, 2020 at 12:15 PM
    #263
    Island Cruiser
    Kauai
    Baja
    Sweet lol! The only off-roading I do and enjoy are dirt roads/fields and sand, so full articulation isn’t a norm for me but I have bottomed out on harsh dips at moderate speeds which I did end up rubbing my flares due to the compression. Nothing to cry about though
  4. Feb 20, 2021 at 3:45 PM
    #264
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    Gonna go slice and beat the pinchweld outwards tomorrow.
    Got some black rubberized Rustolem for afterwards.
    I'll heat gun the fender liners while I'm at it.
    Hopefully after that and an agressive CMC I should be close to good for my 35/11.5/17 Toyo AT3s.
    I expect to have to do a little front fender cutting with my Jigsaw.
    What type of blade for the jigsaw do you guys recommend?
    Island Cruiser likes this.
  5. Feb 20, 2021 at 7:27 PM
    #265
    Island Cruiser
    Kauai
    Baja
    I’ve read guys using fine tooth blade for sheet metal
    Jacked Burton[QUOTED] likes this.
  6. Feb 20, 2021 at 7:30 PM
    #266
    Jacked Burton
    Your Heiniresi avatars reminds me of "jumping" randos in Myrtle Beach.
    Bless you my child for I had sinned.
  7. Jun 1, 2021 at 11:38 AM
    #267
    seniorredwood
    seniorredwood Assistant to the Regional Manager
    Pennsylvania
    2017 TRD Sport, 4x4, MT, DCSB, MGM.
    Has anyone done this mod without removing the front wheels?
  8. Jun 1, 2021 at 11:42 AM
    #268
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Just take off the 6 lugs! Its gonna be quicker to removeit, whackit and reduggait, with the extra space! I couldn't imagine trying to swing a hammer with the tire still on.
    I'm sure someone has, but I'm a fat ass so I need rooooom!
  9. Jun 1, 2021 at 11:44 AM
    #269
    seniorredwood
    Pennsylvania
    Haha I don’t have all the tools needed to remove the wheels.
    Chunk[QUOTED] likes this.
  10. Jun 1, 2021 at 11:47 AM
    #270
    Chunk
    2016 DCSB OR
    Baby Ruth
    I'd be more concerned with acquiring the proper items to replace a wheel/tire than beating a pinch weld! But you do you! :fistbump:
  11. Jun 1, 2021 at 11:47 AM
    #271
    Island Cruiser
    Kauai
    Baja
    Your truck comes with those tools from factory. Only thing you’ll need is a torque wrench
    Slashaar likes this.
  12. Jun 1, 2021 at 11:48 AM
    #272
    Chunk
    2016 DCSB OR
    Baby Ruth
    My guess is aftermarket wheel locks or splines he doesn't have a key for.... Could be wrong, could just be a basic socket, but no one would post that if they had a basic socket and not fancy lugs!!! Right?
  13. Jun 1, 2021 at 11:53 AM
    #273
    seniorredwood
    Pennsylvania
    I don’t have a jack or torque wrench. I know the truck comes with an emergency jack. I was just wondering if anyone has done this without removing the front wheels.
    If the front wheels need to be removed I’ll run down to harbor freight.
  14. Jun 1, 2021 at 11:57 AM
    #274
    Island Cruiser
    Kauai
    Baja
    We’ll find out lol
    Stock wheels? Original owner? There should be a bottle jack too under the rear seats(for 2nd Gen anyway). I tried doing this mod without removing my wheels and they certainly get in the way. I was getting frustrated just removing that part of the wheel well liner. You can try if you want, that’s the only way you’ll find out. Turn the steering wheel to full lock on one side and see if it gives you enough room
  15. Sep 6, 2021 at 9:40 PM
    #275
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    I'm gonna need to do this soon. What tires are these I'm going with the mickey Thompson Baja Boss Mts
  16. Jan 14, 2022 at 3:43 PM
    #276
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Well, that was an easy mod. The most time consuming part was saving the clips (all but 1, but fuck that one...it had it coming). I think the BMC is inevitable but for now I have solved my rub issue:spy:. Minor trimming here and there and no rub where i used to:taco:, but still pretty close to the body mount.
    285/75r16 General Grabber ATX's.
    Island Cruiser and Slashaar like this.
  17. Jan 14, 2022 at 3:49 PM
    #277
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    You can get away from doing the BMC as long as you have an adjustable Caster UCA like the SPC and stay in the 33" tire size. Maxed out you get around +4 Caster and will stay out of the body mount. My cam tabs are bent and I now have +5 Caster because Firestone's incompetent. Before that they reset my caster and I ended up in the Body mount and I ended up chopping it before I realized their mistake. Doesn't help though I also have 0 offset 9 wide wheels with 1.25" Spacers which threw me back a bit at lock. But if you really want to avoid it, even though its an easy 2 hour project with a good welder, death wheel, and some scrap metal, grab some Caster adjustable UCAs.
  18. Jan 14, 2022 at 3:58 PM
    #278
    powder1134
    I just recently installed new JBA UCA's. I love em, but no Caster Adjustment (I had little to no rubbing with my stock UCA's). At the same time I upgraded my springs and went from the top setting on my Bilstein 5100's to the second from bottom (thats when the rub began). For now I think I'm good with the elimination of the rub, but once it is time for new tires I think it'll be BMC time as well.
    Slashaar[QUOTED] likes this.
  19. Jan 14, 2022 at 4:03 PM
    #279
    Slashaar
    Josh
    Kansas City, MO
    BAMF has the plates pre-cut for like a $20 bill IIRC, or just find some scrap metal for filler. I ended up only using one BAMF plate and then had to make the other out of scrap because I got a little ham and cheese with the death wheel and cut off more than the plate covered.
  20. Feb 23, 2022 at 4:30 AM
    #280
    The Pirate
    The Pirate Takoyaki Takoma
    I’m interested in these liners, how do they fit? Do you have any pictures?
