Beating your pinch weld flat with a sledge hammer. --Let's discuss!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Apr 6, 2016.
  1. Mar 23, 2017 at 7:58 AM
    #81
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    manncyclesupply and Crom[OP] like this.
  2. Mar 23, 2017 at 8:37 AM
    #82
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    just what i wanted to hear. thanks for help TW!
    AbunaiTaco likes this.
  3. Mar 23, 2017 at 1:25 PM
    #83
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just left the clips in but was able to pry the fender liner off with a flathead screw driver. I did only a few clips, pulled the liner back, and hit it with a hammer outwards a few times. Then just put the liner back no problem. Took me all of 3 minutes with the tire already off.
  4. Mar 6, 2018 at 11:34 PM
    #84
    Babyjake16
    Babyjake16 @project_traitor
    Jake
    Utah
    2008 Super White Tacoma
    33" Nitto Trail Grapplers 17" TRD Matte Black Wheels ICON Stage 5 w/ differential drop 30% Tint 2 - Pioneer 12" Shallow Mount Subs Focal Speakers Pioneer Head Unit 2 - Pioneer Amps Custom Stickers/Badges Paracord Grab Handles Painted Interior (all panels, headliner and carpet) Clazzio Leather Seat Covers with leather arm rests Ditch Lights 3 - 8" HieseLight Bars in bumper Rock Lights - Cali Raised LED Custom Fabricated Front Bumper - Blackout Fabrication Rock Sliders - DOSECC Fabrication Bushwacker Fender Flares (color matched) Morimoto LED Fog Lights
    DAMN GINA! You just bash the whole thing to hell?
  5. Mar 6, 2018 at 11:47 PM
    #85
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    Since this thread got bumped back up...
    I followed @Crom 's advice and beat mine from the inside out and then reformed the wheel well liner with a heat gun. I'm running 285/75/17 (34's not the standard 33's) and so far so good with rubbing. I flexed the truck and turned lock to lock with my forklift and it looks like I am good. I expect to find spots that will require more attention after I stuff the tires wheeling but on the street and forklift I'm good. FWIW, I'm running about 2" over stock in the front with a CMC, SPC/LR UCA set to 2.5 caster, and I trimmed the bottom of the fenders and flares.
    If you're considering this, get the hammer out and beat it like a 14 year old who just found daddy's playboy; it will take about the same amount of time.
  6. Mar 6, 2018 at 11:52 PM
    #86
    Babyjake16
    Jake
    Utah
    Running 35s and i recently found out how bad pinch weld rubbing can be while off road.. so I agree with your statement. Don’t delay this if you want bigger tires. Will be beating this bitch tomorrow
  7. Mar 7, 2018 at 6:53 AM
    #87
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    I beat mine to the inside. Honestly, the clearance between inside or outside is so small - for ME, it didn't really matter.
    remgu2000 likes this.
  8. Mar 8, 2018 at 7:04 PM
    #88
    remgu2000
    remgu2000 Keepin' on keepin' on.
    Ray
    Roswell, GA
    Used to have a 2017 Barcelona Red TRD Off-Road DCSB 4x4
    Doing this this weekend! After CMCing today, this is a must with 285s.
    abqnurse80 likes this.
  9. Mar 8, 2018 at 7:24 PM
    #89
    Pigpen
    Dan
    Northwest Montana
    But there are so many posts about 285s not rubbing with 2-3" lift and no trimming :rofl:
  10. Mar 8, 2018 at 7:29 PM
    #90
    Pigpen
    Dan
    Northwest Montana
    I enjoy the fact that my 255s took zero work to fit, but damn, those 285/75/17s are bad fucking ass!
  11. Mar 8, 2018 at 7:45 PM
    #91
    Thebubble
    Southern California
    2006 GX470
    Okay, did mine long ago.... doesn’t matter if you beat them in or out, you’ll have clearance for 35s...
    Use the 3M urethane Body seam sealer, usually in a “sausage” gun config. ( for those of you who are in the auto body world ). Excellent stuff, handles just like house hold caulking, except you’ll need acetone to clean it off you or your tools ( compliant solvent. ). Hell, at 75 degrees F and relative humidity at 50% this is paintable or coatable within 30-45 mins.
    So far- no water intrusion whatsoever.
  12. Mar 8, 2018 at 8:11 PM
    #92
    Pigpen
    Dan
    Northwest Montana
    This thread makes me want to do the prep work. It's inevitable that some day I'll find the urge to put some fat meats on the old girl.
    remgu2000 and Babyjake16 like this.
  13. Mar 9, 2018 at 5:02 AM
    #93
    remgu2000
    Ray
    Roswell, GA
    Yeah I don't get that. What do people get out of making such false statement?
    ZebraScissors likes this.
  14. Mar 11, 2018 at 7:46 AM
    #94
    Sandia Labs
    Sandia Labs Well-Known Member
    Colorado via Brawley, CA
    Clazzio all around, ARE topper, Total Chaos bed stiffeners, Tacoma bed mat, Weather tech floor mats, Cab mount chop
    We installed some SEMA wheels wrapped in (GY Duratrac) 265/70/17's. I have rubbing, I will be doing this while doing a little trimming. I also purchased the plastic welding kit they sell at Harbor Freight. Does anyone have experience with this kit? It was 15.99 plus tax.
    MightyMouseTom likes this.
  15. May 13, 2018 at 2:41 AM
    #95
    Tacoma/Taco
    Tacoma/Taco Well-Known Member
    Josh
    Southern Maine
    Tacoma13'build in process
    3inKing coilover with clickerreservoirs 600lb King struts clicker reservoirs Total choas UCA Total choas Race series LCA Total choas bed stiffnners Timberland bump stops front/rear Welded gusset All pro aluminum apex bumper Warn 9000 Pia fog lights Pia off road light led Baja light bar Spider projection lights U bolt flip kit All pro 3in expedition leafs ARB front & rear locker ARB twin compresser Large ARB tank 4:56 gear ratio CBI slider bolt on CBI rear bumper steal Marlin crawler Taco Box 4:7 Optima blue top BFG 285/75R17 mud tires Body mount chop 1.25 wheel spacer Budbuilt Full body armor with crossmember support for dual transfer case skid plate Redirected exhaust Spider headlights warn Synthetic winch line Factor 55 fairlead Fiberglass hood, front-rear fender wells Beaded rims Spare tire mount in bed
    Are you finding the water coming in from daily driving or from mudding/ water crossings? I’m planning on beat the crap out of mine in the next few days
  16. May 13, 2018 at 2:46 AM
    #96
    Tacoma/Taco
    Josh
    Southern Maine
    I know this is an old thread, I’m hoping the taco gods will graise me with a quick response , what size sledge ideally do I need, I have a tendency of destroying shit so I want to be as delicate as I can me if that makes any sense
  17. May 13, 2018 at 2:58 AM
    #97
    Tacoma/Taco
    Josh
    Southern Maine
    Going to the dang store around nine grab a sludge hammer, go to wallyworld throw her up in jack stand, pull of my 34in tires and beat my bitch silly, please Yota gods don’t allow me to break something I can’t fix.. will report back.. I live in rainy, snowy Maine so what would be the best sealent to work with?
    EatSleepTacos and Drainbung like this.
  18. May 13, 2018 at 9:42 AM
    #98
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    No, just make sure you don't penetrate through and make a hole. When I had beat my pinch weld, I sprayed it with rubberized undercoating to seal any hole I couldn't see. Since then I have cut and removed the pinch weld and welded back the fender to fit bigger tires.
    Rob Daman likes this.
  19. May 13, 2018 at 12:43 PM
    #99
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I used a 3lb sledge on mine. The lower you go the harder it gets. Don’t be afraid to beat that bitch into submission.
    I had to beat that shit with all my might, on both my 05 and 15. Unless you only hammered the upper part, I don’t know how you got away with a dead blow.
    Greg.Brakes.Tacos likes this.
  20. May 13, 2018 at 12:58 PM
    #100
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I thought I did too but need to hammer it a little more apparently. Damn big tires and their rubbing problems.
