Because Baja!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brandon###, May 10, 2013.
  1. Jan 1, 2014 at 1:18 PM
    #381
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    The OME can't hold a candle to the Baja setup. I read up on the OME, and the show stopper was all the complaints about "it makes a clunking noise going over speed bumps". Really? Why spend money on a suspension system that doesn't have enough down travel to handle speed bumps . . . . .
  2. Jan 1, 2014 at 1:44 PM
    #382
    monkeyface
    Colorado
    Congrats. Happy New Year. You put some work into it, eh? It was easy for some of us, apparently not for you.
  3. Jan 2, 2014 at 3:59 AM
    #383
    Hot2na
    Hot2na Well-Known Member
    yeah, a tough find....but I'm glad I got it ....NOW : for those of you that have done the install : any helpful hints ????
    thanks .
  4. Jan 2, 2014 at 2:40 PM
    #384
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Care to share where you found it at? Congrats!!
  5. Jan 2, 2014 at 5:08 PM
    #385
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    I had my local dealership check today, all the parts are available separately except the hardware and the bushings.
    If anyone has availability on those items, all the parts could be sourced.
    I will say that the price for all the parts purchased separately will be more than the kit...
  6. Jan 2, 2014 at 7:15 PM
    #386
    ThatguyJZ
    Jim
    TRIAD, NC
    Thanks for that info.
    Generally speaking, is there any speculation as to whether or not the whole kit will be re-available whenever they begin producing the '14 Baja's?
  7. Jan 2, 2014 at 7:21 PM
    #387
    AEmedic
    Boise, ID
    The manager I spoke with thinks that the issue has been production related. The other reason for blocking sales is quality related issues...
  8. Jan 3, 2014 at 5:20 AM
    #388
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Speaking of quality issues, I noticed yesterday that there is already rust forming on the hoses for the rear remote reservoir shocks. The shocks and reservoir housings are aluminum, and the hoses are braided stainless. However, the part of the fittings that is crimped to the hoses are neither, and are starting to rust. Had it since June, and in the snow/salt for perhaps a month.
    Did the dealer say what quality issues they are seeing?
  9. Jan 3, 2014 at 5:32 AM
    #389
    tacoma steve
    tacoma steve Well-Known Member
    NH
    2012 TX Baja
    I have this same problem. I went to dealer to see if this was covered under warrenty the said no. I took some semichrome polish, got them looking nice again put a little oil on them but they are rusty again.
  10. Jan 3, 2014 at 7:26 AM
    #390
    AEmedic
    Boise, ID
    I think she was speculating on what would drive Toyota to block orders on specific items, not specifically referring to any issues with this kit...
  11. Jan 3, 2014 at 9:23 AM
    #391
    PaulK
    Paul
    Pittsburgh, PA
    I wonder if they will cover it when the hoses let go and leak shock oil all over everything. I think I'll clean mine up and put some flat black paint on the affected area.
  12. Jan 3, 2014 at 3:05 PM
    #392
    monkeyface
    Colorado
    I'm not seeing any rust, doubt it will be an issue.
  13. Jan 3, 2014 at 3:10 PM
    #393
    monkeyface
    Colorado
    Further back in the thread you'll find some. The rear brake line extension was the only thing I had a problem with. The front springs/shocks were impossible to compress with my spring compressor, I had my neighbor put them together at his shop.
  14. Jan 3, 2014 at 5:26 PM
    #394
    Brandon###
    Brandon### [OP] Well-Known Member
    the brake line extension is 1 bolt that should take all of 2 minutes to swap in
    i installed the front springs and shocks without using a compressor. it was pretty easy to do.
    that sucks you had trouble with it
  15. Jan 13, 2014 at 9:53 AM
    #395
    PaulK
    Paul
    Pittsburgh, PA
    I have exchanged a couple of emails with Toytec dealing with rear droop and the possibility of getting a full 3" lift in front while retaining the BAJA suspension. They have a Baja-specific aluminum 1" coil spacer (spring seat replacement) available.
    http://toyteclifts.3dcartstores.com/1-Front-Lift-for-BAJA-TRD-Tacomas_p_1065.html
    They then recommended their single AAL or their progressive 3-leaf AAL to get the back up another 1.5" and help with droop under load.
    http://toyteclifts.3dcartstores.com...af-for-Tacoma-with-rear-TSB-springs_p_16.html
    http://toyteclifts.3dcartstores.com/Toytec-Progressive-3-Leaf-Add-A-Leaf-Pack_p_976.html
  16. Jan 13, 2014 at 11:09 AM
    #396
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I've been sitting on this decision for a while now. I don't like how the back isn't raised, I like a bit of rake. I'd also like to increase the resistance to weight in the back.
    I'll most likely be going with the progressive 3 leaf pack. What would you guys recommend doing:
    Keep the overload or remove it?
  17. Jan 13, 2014 at 11:22 AM
    #397
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
  18. Jan 13, 2014 at 11:46 AM
    #398
    PaulK
    Paul
    Pittsburgh, PA
    From the website: Use with your stock overload for 2” of rear lift and extra rear weight. May be used without the factory overload for best ride quality and about 1.5” of rear lift.
    Also had this foot note at the bottom, but I haven’t followed up to see if this would apply to Bajas: Mini-AALs require at least ¾” of thread showing on your current U-Bolts or new longer 7.5” U-Bolts are required.
  19. Jan 13, 2014 at 11:48 AM
    #399
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks, I read that too.... just wondering what other Baja owners would suggest?
  20. Jan 13, 2014 at 11:55 AM
    #400
    PaulK
    Paul
    Pittsburgh, PA
    Me too! I just sent an email to Toytec asking them is the shocks and brake line can take an extra 2" of rear lift, and if we would need new u-bolts. I'll post what I get back from them.
