Because Baja!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brandon###, May 10, 2013.
  1. May 14, 2013 at 2:53 PM
    #101
    stainbrain
    stainbrain Member
    The stock rings seem to work fine if you hit a rock or a curb, that could damage the rim itself, but I am sure the aftermarket can do it better. I know they can make me a better driver.
  2. May 14, 2013 at 3:29 PM
    #102
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
  3. May 14, 2013 at 3:38 PM
    #103
    Del Scorcho
    Eagle, ID
    You could probably get the rings powder coated or even anodized another color. It would kind of depend on how they came finished from the factory.
    Or just 'derp the shit outta them....
  4. May 14, 2013 at 4:11 PM
    #104
    ZeroX
    ZeroX City Slicker
    Anthony
    Brooklyn NY
    2013 Baja Double Cab
    Nice baja vids. To the OP, it's your money, spend it however you want man. This all comes down to what your going to use the truck for , preference. It's nice to take input from others, but if there's one thing I've learned from auto forums, majority opinions arnt always correct. Just keep that in the back of your mind.
  5. May 19, 2013 at 11:05 PM
    #105
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    OP do you know how long your springs are uncompressed?
  6. May 20, 2013 at 6:57 PM
    #106
    Brandon###
    Brandon### [OP] Well-Known Member
    I can post up some measurements this weekend.
  7. May 21, 2013 at 7:33 AM
    #107
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Okay sounds good. I am going to swap out a heavier coil, but I want to know the specs of the springs I have. I am not sure what the spring rate of these coils are.
  8. May 21, 2013 at 9:35 AM
    #108
    Brandon###
    Here is the info I could find.
    Tech Tidbit:The 3-inch-diameter front coil springs are manufactured by Eibach for TRD. They are off-the-shelf race units rated at 650 lb/in. That's slightly softer than the stock springs.
  9. May 21, 2013 at 12:23 PM
    #109
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I saw that article also. I know that the stock springs are 540 which confuses me since that article says slightly softer than stock.
  10. May 21, 2013 at 4:30 PM
    #110
    Brandon###
    maybe it was a typo. i would think they would be stiffer than stock springs
  11. May 21, 2013 at 4:35 PM
    #111
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    1500 for cool TRD stickers on the shocks and coils.
  12. May 21, 2013 at 5:50 PM
    #112
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    haha! You know what is worse than $1500 for cool TRD stickers on shocks and coils that make the OP happy? People that don't read a whole thread and then make a troll comment.
    It is better set up than Toytech or OME for sure. I am happy with my suspension and I OP really likes his.
  13. May 21, 2013 at 5:55 PM
    #113
    littleblue81
    littleblue81 Well-Known Member
    If everything goes according to plan I will have this same package (with the addition of Icon AAL's and Firestone Ride Rites) after the weekend. Hopefully I will be a happy camper.
  14. May 21, 2013 at 6:13 PM
    #114
    Brandon###
    Yeah, you're right.
    (We should put a lock on this forum where gen 1 guys can't access it)
  15. May 21, 2013 at 6:22 PM
    #115
    Brandon###
  16. May 21, 2013 at 7:21 PM
    #116
    ManMan
    ManMan Well-Known Member
    Why AAL's and airbags? Just run more psi in the bags
  17. May 21, 2013 at 7:28 PM
    #117
    littleblue81
    Went back and forth a bunch on that part. In the end I wanted the suspension adequately provide the lift and other suspension duties and the air bags to be inflated with load (I know they have to have a min amount of psi).
    Found a ton of info on airbags in general but not so much with lifts. This approach made sense to me.
  18. May 21, 2013 at 7:29 PM
    #118
    littleblue81
    Oh, also when you order the kit it doesn't come with an extra leaf and the Baja's come with the 4 leaf pack.
  19. May 21, 2013 at 7:56 PM
    #119
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    X2
  20. May 21, 2013 at 8:09 PM
    #120
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Subbed
