Because We're Not North Enough To Be NOVA, We're Just Stuck Between the North and the True South
Discussion in 'Virginia' started by Wild Crow, Sep 21, 2016.
  1. Apr 13, 2017 at 7:09 PM
    #2521
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Do you want the hitch as well?
    Casper66 likes this.
  2. Apr 13, 2017 at 7:10 PM
    #2522
    Wild Crow
    Wild Crow [OP] Well-Known Member
    James
    Anywhere is home
    2014 Baja
    Frickin no it all!
    Why would you want to remove it?!
    Serially, I never thought of that option, points to you C, I was only thinking of better adhesion...
    Casper66[QUOTED] likes this.
  3. Apr 13, 2017 at 7:10 PM
    #2523
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    I already have a hitch, just the bumper. Mine is all damaged from the previous owner.
  4. Apr 13, 2017 at 7:11 PM
    #2524
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    hunnert seems fair for a straight bumper
  5. Apr 13, 2017 at 7:11 PM
    #2525
    Dimestore55
    William
    Richmond, VA
    Yeah, why the hell would I want to remove it?
  6. Apr 13, 2017 at 7:12 PM
    #2526
    TacoFMS
    Justin
    Louisa County, VA
    You ever decide on that spare?
  7. Apr 13, 2017 at 7:14 PM
    #2527
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    Lol. I'll pass. They're pretty much the same. Must be sumpin about the way spares sit under tacos. My tundra spare has good sidewalls, the taco not so much.lol
  8. Apr 13, 2017 at 7:16 PM
    #2528
    TacoFMS
    Justin
    Louisa County, VA
    Ok. Just thought I would check.
  9. Apr 13, 2017 at 7:19 PM
    #2529
    Dimestore55
    William
    Richmond, VA
    I'll hit you up later about the bumper, I have to pay my taxes this week.
  10. Apr 13, 2017 at 7:19 PM
    #2530
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    No problems. I knew I forgot to get back to you.....after you asked!
  11. Apr 13, 2017 at 7:25 PM
    #2531
    TacoFMS
    Justin
    Louisa County, VA
    Sounds good
  12. Apr 13, 2017 at 7:58 PM
    #2532
    Fish12South
    Fish12South Well-Known Member
    Steven
    Ruther Glen, VA
    2008 Indigo Ink AC SR5 6 Speed V6
    Not Enough.
    I know I'm late to the party, but I'm planning on going Blue Sea. I'm pretty sure as OCD as I am about wiring, I can make it pretty enough for me to live with.
    Dipped mine. Twice.
    Pro tip for you... Since you're going to already have the bumper off, take the time to pull the plastic pads off. I dipped mine on the truck and tried to tape them off. First round the tape was wrapped under the plastic pad (because I'm from a family of painters, and that's how you do it), not realizing that PlastiDip doesn't follow ANY of the rules of paint. So when I peeled the tape, I peeled the dip. So, second time, I left a half inch section of plastic showing, sprayed the shit out of it, and it actually peeled off the plastic and cut at the seam, just like advertised.
    If I would have had the bumper off the truck, I just would have popped the pads off and went to town.
    Also, medium see through coat, another medium coat after that, then pretty much just hose the shit on just to the point that you get nervous about it running (again, relatively speaking compared to paint). I waited about 10 minutes between coats. Thicker is better, and makes it way easier to peel when the time comes. Because it will eventually.
    Also, whenever you do it, hit me up. If I'm free, I can ride down and lend a hand.
    Yes. You'd connect the 12V power and the reverse 12V to the same hot wire on the light. But put a diode in the wire going to the reverse light. Simple, easy, and what I'm going to do with my new one eventually. Once I get it. And get it installed. And then get time.
    Also, before I make a FS post, anyone need some factory fogs? These things have been sitting on the shelf since I got the ARB. Used, decent shape, one has slight hazing but not completely hazed over.
  13. Apr 13, 2017 at 8:12 PM
    #2533
    Dimestore55
    William
    Richmond, VA
    Thanks for the offer, I will definitely take you up on it as soon as I get everything sorted. I need to get the bumper, lights, and one new plastic pad from the dealer to replace a damaged one from my original. I've got a pretty decent jigsaw and some files to make he cutouts for lights.
  14. Apr 13, 2017 at 8:19 PM
    #2534
    Fish12South
    Steven
    Ruther Glen, VA
    Not Enough.
    No worries. As of right now, I've got weekend stuff going on this weekend all weekend, going to the truck and tractor pull in Miller's Tavern next Saturday night (which is awesome, and not too far from you, if you wanted to check it out), and then might be (probably will be) in the OBX the weekend after that. But so far I think May is pretty free, except I really want to go camp up in the GWNF one weekend before it gets stupid hot. I really need to slow down sometime... :rofl:
  15. Apr 14, 2017 at 2:46 AM
    #2535
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    It can get nicks or tears in it. I cought an edge on mine with the power washer and it started to peel. Or it gets dingy looking and you want to freshen it up ( I have a cure for that also) so you just peel off the old and re spray it. Rt on the truck no need to take back off. It also acts as a good chip guard against rocks
    Wild Crow[OP] likes this.
  16. Apr 14, 2017 at 2:59 AM
    #2536
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    If you get the same type of lights I did they are square pods. I used a die grinder with a cut off wheel for n it to make a square cut
  17. Apr 14, 2017 at 2:59 AM
    #2537
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Good morning everyone
  18. Apr 14, 2017 at 4:41 AM
    #2538
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    @ffxcounty
  19. Apr 14, 2017 at 4:48 AM
    #2539
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I'm trying to tag this guy to ourcthread he's moving out by me. I have to get his correct screen name as he just joined TW. He's has all his oem parts from his '06 tacoma he's trying to sell he said $50 for all of it he just wants it gone before he moves
  20. Apr 14, 2017 at 5:14 AM
    #2540
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    @FKFFX county654 this will be your local thread you can tell everyone here what your selling( he can't post in the marketplace yet) welcome to TW!
