Because We're Not North Enough To Be NOVA, We're Just Stuck Between the North and the True South
Discussion in 'Virginia' started by Wild Crow, Sep 21, 2016.
  1. Oct 2, 2017 at 4:45 AM
    #4521
    Kyle_sprouse
    Kyle_sprouse Well-Known Member
    Kyle
    Orange, VA
    99 taco (sold) 2011 Trd off-road taco (current)
    3inch bilstein toytec lift (front) All pro off-road “expo” leaf pack with Fox 2.0 shocks (rear) , 285/75/16 falken wildpeak MTs, stealth custom series Stealth 6 wheels (dark bronze 16x8 3.50” -25mm), Max modular bed rack, smitty bilt RTT, Dobinson 4x4 snorkel, Cali raised LED ditch lights, blue sea aux fuse panel, off grid engineering rear power source, paranoid fabs switch panel, brute force fab front bumper, arb 2500 awning.
    This is from skyline. Misses that whole conversation but it’s it’s a fun place to go cruise around and hangout..... unfortunately my truck is out for the count right now so haven’t been active much or really driving it. Burning a whole lot of oil, no visible leaks. Replaced the pcv valve cleared it up a little then changes the plugs and now I’m smoking a lot. Running a compression test this evening once my brings it over and gonna check for a cracked ring or a hole in my piston. (Praying it isn’t one of those two so I don’t have to motor swap) if it’s not a cracked ring then my next assumption would be valve seals are gone or that when I pulled my valve cover the drain holes inside are stopped up. It’s just bothering me because all of my plugs were fouled and had oil on them and I can’t seem to google what would cause that problem.
    Casper66 likes this.
  2. Oct 2, 2017 at 5:45 AM
    #4522
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Sounds like a cracked oil ring or rings but you may not know until you crack it open. You can do an engine swap if its needed but why not just rebuild the one you have?
    Kyle_sprouse[QUOTED] likes this.
  3. Oct 2, 2017 at 5:55 AM
    #4523
    Kyle_sprouse
    Kyle
    Orange, VA
    If It’s rings my plan is to pull it put a used motor back in then rebuild my old one on my own time and then have an extra motor if ever needed. In the time it would take me to rebuild and do new rings I could have it swapped and driving again
    Casper66[QUOTED] likes this.
  4. Oct 2, 2017 at 9:42 AM
    #4524
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    This isn't necessarily for taking pictures of my truck.
  5. Oct 3, 2017 at 3:47 AM
    #4525
    Kyle_sprouse
    Kyle
    Orange, VA
    Well compression test came back good all cylinders were with in 10psi from one another and you are allowed 15psi before you declare it having a bad ring... so good news is motor shouldn’t have to be pulled. Now it’s just a matter of figuring out where the hell oil is getting sucked from the oil pan to the throttle body. Had a guy tell me last night that if the intake gasket goes bad it makes a weird vacuum and would cause it to pump oil to the throttle body so this evening gonna pull the top of the intake apart and see if any oils in there. He said if I have a bunch of oil in there then the gasket will fix my oil loss/burnage. However if oil isn’t in there then it’s back to square 1.... also pulled the passenger side valve cover off to make sure the drains were working probably and both drains were clear and no oil puddled up in there.
  6. Oct 8, 2017 at 10:35 AM
    #4526
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    So this was how I spent my Friday.
  7. Oct 8, 2017 at 10:43 AM
    #4527
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    Truth
    TacoFMS[QUOTED] likes this.
  8. Oct 8, 2017 at 11:20 AM
    #4528
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Nice. What ratio and diff did you go with?
  9. Oct 8, 2017 at 11:36 AM
    #4529
    TacoFMS
    Justin
    Louisa County, VA
    4.56, not real sure what you are asking about the diff though...
  10. Oct 8, 2017 at 12:04 PM
    #4530
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Air locker, truetrac, open diff, e-locker. Looked in your build thread and saw it's the air locker.
  11. Oct 8, 2017 at 12:07 PM
    #4531
    TacoFMS
    Justin
    Louisa County, VA
    Yep arb in rear. Never been much of a fan of the truetrac ever since I had a scary moment in one. But that's just my personal hang up.
    Coot83 likes this.
  12. Oct 9, 2017 at 4:08 AM
    #4532
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I need to get up and ride in it to see how the 4.56s are. Def sick to see your truck get some serious love this weekend! :thumbsup:
  13. Oct 9, 2017 at 4:14 AM
    #4533
    TacoFMS
    Justin
    Louisa County, VA
    Thank you sir. Can't "get up and go" right now as I am still in the break in period and have to baby it. But it definitely made a huge change. Especially after driving so long on stock gears and dirty foe's
    Coot83[QUOTED] likes this.
  14. Oct 9, 2017 at 4:24 AM
    #4534
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Yea I def know what you mean, would be cool to check out how smooth it is on the gears. I think if my truck could have that stock acceleration and gearing feel where every hill isn't killing it, would be a nice change for it.
  15. Oct 9, 2017 at 4:38 AM
    #4535
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Damn, wish I would have seen this thread while I was stationed in Dahlgren.
    Coot83 likes this.
  16. Oct 9, 2017 at 4:40 AM
    #4536
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Still somewhat local though!
  17. Oct 9, 2017 at 4:42 AM
    #4537
    Comatose
    Miguel
    San Diego, CA
    Well now I'm in Richmond for 30 days of leave, then I'm getting stationed at Wallops Island. Is there any "Most Northeast" groups?
  18. Oct 9, 2017 at 7:56 AM
    #4538
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    There's a Maryland thread in the NE region section that's pretty active. There might be an eastern shore or VA beach thread in this section.
  19. Oct 9, 2017 at 3:40 PM
    #4539
    CharlieWork
    CharlieWork Active Member
    VA
    2017 Tacoma TRD OR DCLB
    ARE MX Mobtown Sliders
    Just back from putzing around Fire/Forest Rd 151 between Criders and Brandywine- no issues in the stock DCLB.
    Wild Crow[OP] likes this.
  20. Oct 10, 2017 at 3:07 AM
    #4540
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    in front royal there are unused train tracks, that have overgrown weeds and grass. Right in town.
    http://www.abandonedrails.com/Southern_Railway
    Also, If you do decide to come out front royal way, let me know.
