Because We're Not North Enough To Be NOVA, We're Just Stuck Between the North and the True South
Discussion in 'Virginia' started by Wild Crow, Sep 21, 2016.
  1. Sep 27, 2016 at 3:13 PM
    #141
    Wild Crow
    Wild Crow [OP] Well-Known Member
    James
    Anywhere is home
    2014 Baja
    No. Don't really know about them. I'll have to check them out
  2. Sep 27, 2016 at 3:15 PM
    #142
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Opinion? Yes they're all way to damn exspensive. I'd be happy with the eBay bumper but too heavy for my little 4 banger
  3. Sep 27, 2016 at 3:18 PM
    #143
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    Weight is what I'm trying to avoid all the while being prepared to travel who knows where around the country for a year or so. I'm planning on aluminum skids too
  4. Sep 27, 2016 at 3:21 PM
    #144
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    They have a weld it yourself aluminum version for about $900 and in South Carolina so shipping shouldn't be ridiculous.
  5. Sep 27, 2016 at 3:22 PM
    #145
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I have been thinking aluminum everything but was warned that the aluminum skids aren't very sturdy
    90yota likes this.
  6. Sep 27, 2016 at 3:24 PM
    #146
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    And so who has a welder let alone an aluminum welder
  7. Sep 27, 2016 at 3:27 PM
    #147
    90yota
    88 T4R / 15 F350
    Stock....ish
    Just putting that out there because of how cheap it is compared to the complete which is about $1500. Not trying to volunteer anyone if they do have one.
    Casper66[QUOTED] likes this.
  8. Sep 27, 2016 at 3:28 PM
    #148
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    There is an sos concepts bumper group buy going on rt now
    90yota likes this.
  9. Sep 27, 2016 at 3:36 PM
    #149
    90yota
    88 T4R / 15 F350
    Stock....ish
    Good catch on that group buy.Ends 10/10. Makes me want to say screw it and buy one!
  10. Sep 27, 2016 at 3:41 PM
    #150
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    DOOOOOOO ITTTTTTTTT:thumbsup:
    Coot
    Casper66 likes this.
  11. Sep 27, 2016 at 3:50 PM
    #151
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    So the headstrong 5100 kit works out to approximately $650 +/- shipping, taxes, etc. I should be hearing about a position/salary change on thur. So if all goes well:fingerscrossed:, it will happen very soon.:turtleride:
    Casper66 and Wild Crow[OP] like this.
  12. Sep 27, 2016 at 3:51 PM
    #152
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Sounds like things could be getting a little crunchy...
    Coot
    Wild Crow[OP] likes this.
  13. Sep 27, 2016 at 4:28 PM
    #153
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    ok some clarification please. we know what you originally stated the you would like to have. what are you looking at in this kit? i'll take you for a ride in mine if youd like so you can see how it rides prior to ordering. i've already put 2 lift kits on mine and i've only had it since december point being spend your money wisely unless it's no object. i am perfectly confident, through the guidence of some knowlegble friends, that while my truck may not have the fanciest, most exspensive suspension available it is perfectly capable of handling anything i'll encounter here on the east coast.
  14. Sep 27, 2016 at 4:53 PM
    #154
    chiefcrunchy
    Brian
    @Casper66 im looking for mild lift to retain comparable ride capabilities and allowing larger tires for backwoods roaming. Thank you for the offer, I think I need to take you up on it. I'll get my Oct schedule this weelend and we can go from there.
  15. Sep 27, 2016 at 5:07 PM
    #155
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    i'm understanding what you want. what are you looking at in the kit from headstrong? aren't you in chantilly or somewhere? i work at dulles and get off at 2:30
  16. Sep 27, 2016 at 5:11 PM
    #156
    chiefcrunchy
    Brian
    @Casper66. What kit do you have now? My buddy has a rough country 3" that we installed last 2 summer's ago, and it rides pretty rough, that's why I was looking to the HS kit, essentially OE just higer;)
  17. Sep 27, 2016 at 5:15 PM
    #157
    chiefcrunchy
    Brian
    I'll be at work in Burke until 4, however Thursday afternoon I'm off all evening.
  18. Sep 27, 2016 at 5:28 PM
    #158
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    i started with the rough country kit. now i have a collection of goodies not really any kind of kit. the rear is wheeler's 3 leaf progressive aal, rough country shocks,and extended brake lines (yet to be installed). the front is bilstein 5100's set at .85 (second notch) with eibach 112620 620# coils, and superbumps. 2.5" lift in the front and around 3 in the rear. the reason why i was asking what you are looking at in the kit is it can be stock height or lifted depending on what items you select and how they are setup. for instance if you install 5100's set at 0 with your stock coils you'll be at stock height. if you move the struts to a higher setting you'll get lift but negate the benefits of the bilstein strut because you'll preload the coils and in esence end up with the same thing as if you put a spacer in. put an eibach or ome coil like an 885 with your bilstein set at 0 and you'll get the lift you want around 2.5" plus it will allow the strut to work as it should with no preload
  19. Sep 27, 2016 at 5:30 PM
    #159
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    i'll be dropping the truck off at the dealership tomorrow so we'll have to meet up 1 day next week or you can take a little road trip out to my house this weekend and see how it feels on bumpy country roads
  20. Sep 27, 2016 at 5:34 PM
    #160
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    @chiefcrunchy i can drop it off thursday if you'd like to meet me at like the chantilly autopark at 2:30 thursday
