Bed bolt hole stripped
Discussion in '1st Gen. Tacomas (1995-2004)' started by npbow, Aug 3, 2019.
  1. Aug 3, 2019 at 7:22 AM
    npbow
    npbow [OP] Active Member
    In the process of anti seizing the bed bolts I got a little carried away with the impact wrench, and stripped the middle bed bolt(the threads in the bed) .Anyone ever do this, and how did you fix or do you think its not a problem. The other five bolts are fine and tight.
    jonnytacoo likes this.
  2. Aug 3, 2019 at 7:25 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    you can probably re tap the threads if you can find out what the bed bolt thread pitch is,
  3. Aug 3, 2019 at 7:28 AM
    BillsSR5
    bill
    2014 SR5
  4. Aug 3, 2019 at 7:34 AM
    npbow
    Ya thats what i figured was seeing if anyone had a easier solution being I don"t think I can get a tap up there due to the way its frame mounts are shaped (can"t turn tap) and I don't want to take bed off.
  5. Aug 3, 2019 at 7:35 AM
    npbow
    Cant"t get to inside of stripped threads its a enclosed piece of metal on the bed.
    Thanks.
  6. Aug 3, 2019 at 7:36 AM
    BillsSR5
    bill
    2014 SR5
    no you can GOOGLE search the thread pitch but pretty sure its M12x1.25 maybe u can buy a tap and die set, I bought a cheap metric set from AUTOZONE, should be easy to rethread the bunged hole
    GQ7227 likes this.
  7. Aug 3, 2019 at 7:39 AM
    BillsSR5
    bill
    2014 SR5
    yeah I didn't think of that, I took the bed off my 2004 to do a fuel pump so I get what your saying
    GQ7227 likes this.
  8. Aug 3, 2019 at 7:41 AM
    BillsSR5
    bill
    2014 SR5
    maybe the bolt threads themselves are bunged up, I think the bolts are self threading even if the hole is slighty bunged you can force the bolt to thread I think that's how they designed them, or I should say they are self tapping type fastners, maybe 2 new bed bolts and force them in till they retap, also I suggest to anti seize all them bolts in case you need to get the bed off down the line
  9. Aug 3, 2019 at 7:44 AM
    npbow
    I check into it but they were spinning very freely after I went too far with the impack wrench and the bolt threads look fine.
    Thanks
  10. Aug 3, 2019 at 7:46 AM
    BillsSR5
    bill
    2014 SR5
    oh ok got ya, u need to find some way to extend the tap to get around the frame mounts and get up in there
  11. Aug 3, 2019 at 7:49 AM
    BillsSR5
    bill
    2014 SR5
    tony2018 likes this.
  12. Aug 3, 2019 at 7:57 AM
    npbow
  13. Aug 3, 2019 at 8:00 AM
    BillsSR5
    bill
    2014 SR5
    I would check around maybe a some Hardware stores like ACE or HOMEDEPOT probably will be the easiest way to do it,
  14. Aug 3, 2019 at 8:22 AM
    tony2018
    tony2018 Well-Known Member
  15. Aug 3, 2019 at 8:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    My bed has had 4 bolts in for now for 100,000 miles just never took the time to put them in.
    jonnytacoo and cruiserguy like this.
  16. Aug 3, 2019 at 8:57 AM
    Qball808
    Qball808 Member
    HAWAII
    96 Tacoma 2.7
    All motor, intake,lce header,lce big bore throttle body, egr delete,flex fan , lce lighten drive pulley , magnaflow high flow catalytic, flowmaster can. 285/70/17 AT toyo’s :::: Mods 2B done::::: <lce stage 3 head & cams <Lce high boost charger kit/w/maf control <Lce tundra brake conversion <Pistons & rods <Piggy back ecu <4:88 gearing <Oil filter relocation & cooler <Transmission cooler/with fan
    Just un bolt the bed and slide it back so you can tap it in the open. No need to take the bed off possibly will have to disconnect some wires and the gas filler a bit. No biggie. If not just for get it and send it. Should be fine. Good luck.
    jonnytacoo, BillsSR5 and GQ7227 like this.
  17. Feb 15, 2023 at 4:54 PM
    jonnytacoo
    jonnytacoo Well-Known Member
    Jonny
    So Cal
    2018 TRD Off-Road 4x4
    OEM
    I have this same issue. Two of them I’m pretty sure I went to crazy with the impact. Did you fix yours?
  18. Feb 16, 2023 at 8:00 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    OP has not been around since 2021.
