Bed bolt torque spec
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Madchild, Mar 22, 2009.
  1. Mar 22, 2009 at 11:37 AM
    Madchild
    Madchild [OP] Well-Known Member
    Bloomington MN
    Slim's HID, Tonnau Cover
    I search all over the internet and can't seem the find the torque spec for these bolts.
    I'm adding D-rings to my bed and would like to know what the torque spec is for these bolts.
    Thanks
  2. Mar 22, 2009 at 12:57 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    yeah just tighten them down good and tight. If your really worried about it just put some thread lock on the threads before you put them in.
  3. Mar 23, 2009 at 6:39 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    I added 4 D-rings to my bed bolts this weekend. They were not that tight from the factory, I was a little surprised from that but they are just holding down plastic.
  4. Mar 23, 2009 at 8:13 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    I added blue loctite to mine and just cranked them down until tight.
    The D-ring assembly wanted to spin as the bolt was turning. I was using a screw driver to try and hold the d-ring in position but it sill slid so I just got it as tight as I could with the d-ring in position.
  5. Mar 23, 2009 at 11:15 AM
    Brunes
    Brunes abides.
    Rotorhead
    Go with Bubba tight- Find the nearest dood named Bubba and have him crank those bishes down.
    +1 to Vecc on the locktite.
  6. Mar 23, 2009 at 11:20 PM
    Madchild
    Bloomington MN
    the middle 2 bolts were at 50ft/lbs and the back and front ones were at 35ft/lbs when I check before removing the bolts.
