Bed Buddy Installation Qs
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Sep 4, 2010.
  1. Sep 4, 2010 at 11:45 PM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I bought a bed buddy to make loading multiple bikes less of a pain in the neck. I gave it to my mechanic to install when he was doing my timing belt but i needed the truck back before he has a chance to do it. He said that it would be a lengthy process, involving lifting the bed off the frame or something to install. I found this to be odd since Bed Buddy was advertised as being easy to install. Does anyone here have one on their Gen 1 taco? how did you install? how long did it take? I've heard of people tossing the factory fasteners and going with their own. Should I do that? My mechanic said he would feel safer reinforcing it with a plate of steel, since he believes the front of the tacos bed is pretty thin. Did anyone else do this? would it be necessary?
    Thanks
  2. Sep 5, 2010 at 12:02 AM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    :D:D:DBed Buddy:D:D:p
  3. Sep 5, 2010 at 12:09 AM
    x2468
  4. Sep 5, 2010 at 5:34 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I wasn't thinking homo, but maybe bi...
    As far as durability, if you dont use the tie downs on it, it really woudn't be more than a spacer. The instructions seem to point towards some type of anchor bolts, which depending on the type it is, the materials its made out of, and the amount of holes it has will determine its strength. It would also make a difference to me if you could close the tailgate or not. Personally, I wouldn't use the tie downs on it for anything but extra support unless you do as your mechanic said and reinforce it. I honestly dont think some steel plate is necessary. Guess you could get some 3/16"x2"x48" or something at Home Depot for the back side of the bed, but I think you'll be just fine with some large washers, lock washers, and real bolts.
