Bed cage out of square tubing
Discussion in 'Long Travel Suspension' started by Mxpatriot, Apr 13, 2013.
  1. Apr 13, 2013 at 2:13 AM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    I want to incorporate a tool box, battery box, and places for fuel jugs in the bed of my truck when I build the bed cage. It would be much easier for me to build these boxes out of square tube. The boxes will share tubes with the bed cage. Design is based around fitting a dirt bike on either side of the tool box (tool box will run front to rear of the truck, rather than side to side).
    I also want to have points in the bed cage where tubing can be sleeved for a bed rack, for a roof top tent.
    Assuming good geometry (redundant and equalized), is there a significant reason to not build the bed cage out of square tubing?
  2. Apr 15, 2013 at 1:47 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    I'd say go for it if that's what you want. I think most people go with tube because you can bend it for corners instead of having to weld whenever there's an angle, and because bent tube looks cool.
    I don't see an issue with strength, as long as you make it out of equivalent(ish) size square tube.
  3. Apr 15, 2013 at 3:01 PM
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
    The reason tubing is used is because it is stronger on a 360 degree axiswhere square tubing is only strong in 4 planes. Square will tend to fold.
    However, this is just numbers and theoretical yield points of material, andinternet fabbing. If you can design it in a way that functions properly, thendo it!
  4. Apr 15, 2013 at 5:03 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    That's my concern. I think I am just going to gussett and plate the hell out of it.
  5. Apr 15, 2013 at 5:12 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    If it's easier to build out of square, use square. A bed cage will never have "optimal" geometry full of triangulated (diagonal) members, because that would eat into cargo volume.
    You can also use a combination of square and round tubing.
  6. Apr 18, 2013 at 1:50 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I say go for it!
