Bed Cleat Info
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DdayIsNear, Nov 3, 2009.
  1. Nov 3, 2009 at 3:09 PM
    DdayIsNear
    DdayIsNear [OP] Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    Does anyone know the specs....if there are any for the bed cleats that would be on the 05+ or if it is vehicle specific i have an 07. by specs i mean, wieght to support, strength, recommended this or that, manufacturer specs.
    thanks
  2. Nov 3, 2009 at 3:15 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think they are all the same. If they fit the rails- Good to go.
    They are rated to not more than 200 lbs. I wouldn't even trust them with that much, but I've moved my rails out from the edge of the bed to install my tonneau.
  3. Nov 3, 2009 at 3:15 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    They're all the same....
  4. Nov 3, 2009 at 3:20 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i thought they made 2 sizes. some fit under bed covers and some didnt.mine fit under my access cover.
  5. Nov 3, 2009 at 3:40 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think there is a smaller size you can buy after market- They both fit under the covers when the covers come with the rail spacers.
    I have the big cleats- I can't remove them from the rail easily...but I can slide them forward or back as needed.
  6. Nov 3, 2009 at 4:00 PM
    C-Hawk
    C-Hawk Active Member
    For what its worth, the cleats on my son's '10 Tacoma came with a card stating the following.
    "CAUTION Applying loads at an angle to the bed cleat greater than 45 degrees or loads greater than 220 lbs may cause damage to the bed, bed rail system, bed cleat and or the cargo."
    As for us, we plan to install an additional pair of D-Rings with backing plates to secure his RMZ soon.
  7. Nov 3, 2009 at 4:22 PM
    ImpulseRed008
    Susan
    SC
    They do - the big ones, the little ones, plus some little ones with hooks.
  8. Nov 3, 2009 at 4:25 PM
    AK27
    AK27 Well-Known Member
    the big cleats are easy to remove. twist the lock till its loose, pull the cleat inwards and turn.
  9. Nov 3, 2009 at 4:35 PM
    ImpulseRed008
    Susan
    SC
    Not if you have a low profile tonneau cover :eek:
  10. Nov 3, 2009 at 4:37 PM
    AK27
    oops :eek: didnt read that part
    thanks susan!
  11. Nov 3, 2009 at 4:39 PM
    ImpulseRed008
    Susan
    SC
    :cool:
  12. Nov 3, 2009 at 4:41 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Except for when the rail is attached to the rail for my tonneau cover and that tonneau cover rail makes it impossible to rotate the cleats 90 degrees needs to just slip them out.
    I end up taking the end cap off the side rail and sliding them out the end. I don't think I could get them into the rail at the head of the bed if I wanted to.
  13. Nov 3, 2009 at 4:42 PM
    AK27
    lol yup impulse pointed that out to me! :eek:
  14. Mar 9, 2010 at 4:46 AM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    What if you attached metal L shaped brackets to the rail system? How much weight do they support?
    ie: L shaped brackets attached to four 2x10s across the bed to put plywood on top for a sleeping platform.
