bed corner tie downs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Feb 17, 2010.
  1. Feb 17, 2010 at 6:43 AM
    ywen
    ywen [OP] Well-Known Member
    Where else can I strap down on the 6ft tacoma bed? I just want to put some tension down on cargo so it doesn't slide around.. it seems like the corner tie downs are only good for strapping down tall items like a motorbike..
  2. Feb 17, 2010 at 6:48 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Install a couple more "D-rings." You can place them where you feel is best. It's a cheap mod. too. :)
  3. Feb 17, 2010 at 6:53 AM
    ywen
    Hmm is there a write up for installing these on the 1st gens? THanks
  4. Feb 17, 2010 at 2:12 PM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
  5. Feb 17, 2010 at 3:54 PM
    MNTaco
    MNTaco Newbee
    Twin Cities, MN
    2010 DoubleCab TRD Sport Long-Bed
    Bet mat, bug shield, running boards, tonneau cover
    In addition to, or in place of, additional D-rings, you could also get some corner brackets to add to the bedrails which are really strong. I got a pair from JP Metal Fabrication, which has PayPal and sends out pretty quick. Check out their site at http://www.jpmetalfab.com/products.html.
  6. Feb 17, 2010 at 5:38 PM
    ywen
    Thanks for the suggestions. I've been eyeing the core-trax system as well... gonna install them before I get the bed linex-ed
